Extruder problem December 12, 2013 02:46PM |
Re: Extruder problem December 12, 2013 04:08PM |
Re: Extruder problem December 12, 2013 11:34PM |
Re: Extruder problem December 13, 2013 06:01AM |
Re: Extruder problem December 13, 2013 07:00AM |
Re: Extruder problem December 13, 2013 08:24AM |
reprappro
Hi Danie
If you set the motor to extrude 100mm, then hold the large gear, does it feel like it has too little strength?
It does sound possibly like a motor or motor driver problem, though could be wiring. The vref is set in firmware, and should be correct. Can you try swapping the motor from another axis, and reseating all wiring? That should rule out the motors and wiring, and whether it's a board fault.
Ian
RepRapPro tech support
Re: Extruder problem December 15, 2013 06:23AM |
Re: Extruder problem January 09, 2014 03:09PM |
