X/Y Axis movement December 12, 2013 11:46PM |
Re: X/Y Axis movement December 13, 2013 01:10AM |
Re: X/Y Axis movement December 13, 2013 02:03AM |
Re: X/Y Axis movement December 13, 2013 04:36AM |
Re: X/Y Axis movement December 13, 2013 04:48AM |
Re: X/Y Axis movement December 13, 2013 05:00AM |
reprappro
Daniedb
It depends what you are describing moving. The Y axis + and - in your picture shows the nozzle movement relative to the bed, rather than the actual movement of the axis, which is the other way! The motor end is the homing position of both X, Y and Z axis. At 0,0,0 the nozzle should be over the back right hand corner of the bed, just touching the surface.
Ian
RepRapPro tech support
Re: X/Y Axis movement December 13, 2013 05:37AM |
Re: X/Y Axis movement December 16, 2013 01:51PM |
Re: X/Y Axis movement December 16, 2013 04:06PM |
Re: X/Y Axis movement December 16, 2013 04:31PM |
Re: X/Y Axis movement December 16, 2013 05:56PM |
Re: X/Y Axis movement December 16, 2013 06:28PM |
Re: X/Y Axis movement December 17, 2013 04:09PM |
Re: X/Y Axis movement December 17, 2013 04:23PM |
M104 S185 ; set temperature
G28 ; home all axes
G1 Z5 F5000 ; lift nozzle
M109 S185 ; wait for temperature to be reached
