Network connection December 15, 2013 01:14PM |
Re: Network connection December 16, 2013 05:23AM |
NetRange: 169.254.0.0 - 169.254.255.255
CIDR: 169.254.0.0/16
OriginAS:
NetName: LINKLOCAL-RFC3927-IANA-RESERVED
NetHandle: NET-169-254-0-0-1
Parent: NET-169-0-0-0-0
NetType: IANA Special Use
Comment: Computers use addresses starting with "169.154." when they do not have a manually configured address or when they are not told which address to use by a service on the network. They are commonly called the "link local" addresses.
Comment:
Comment: Routers are not allowed to forward packets sent from an IPv4 "link local" address, so they are always used by a directly connected device.
Comment:
Comment: These addresses were assigned by the IETF, the organization that develops Internet protocols, in the Standards Track document, RFC3927, which can be found at:
Re: Network connection December 16, 2013 03:36PM |
Re: Network connection December 17, 2013 07:50AM |
Re: Network connection December 18, 2013 10:17AM |
Re: Network connection December 19, 2013 04:24AM |
Re: Network connection December 21, 2013 03:11AM |
Re: Network connection December 21, 2013 07:03AM |
Re: Network connection December 21, 2013 07:40AM |
Re: Network connection December 21, 2013 08:23AM |
Re: Network connection December 21, 2013 02:04PM |
Re: Network connection December 21, 2013 05:01PM |
My tests were with JP9 removed. Just repeated the test (having found the jumper!)Quote
Ian
@Treth: you may find you get 0.1 or 0.2V more by removing JP9 (5V_EN), if it's on. I *think* it made a difference when I tested it earlier today!
Re: Network connection December 23, 2013 03:30AM |
dc42
Hi Treth, I'm running my Ormerod connected to my laptop, which is wirelessly connected to my router. To get the laptop talking to the Ormerod via Ethernet, I had to bridge the wired and wireless network adapters, so that both can use the same subnet i.e. 192.168.1.x. Bridging the network adapters under Windows is very easy, you just open the network adapters page in Control Panel, highlight both ports, right-click and select "Bridge".
Re: Network connection December 24, 2013 03:21AM |
Re: Network connection December 24, 2013 06:14AM |
Re: Network connection December 24, 2013 06:46AM |
Re: Network connection December 24, 2013 11:25AM |
Re: Network connection December 24, 2013 12:27PM |
Re: Network connection December 24, 2013 02:40PM |
Re: Network connection December 24, 2013 02:58PM |
Re: Network connection December 24, 2013 03:47PM |
Re: Network connection December 25, 2013 02:14AM |
Re: Network connection December 25, 2013 06:36AM |
Re: Network connection December 25, 2013 06:40AM |
Re: Network connection December 25, 2013 09:22AM |
Re: Network connection December 26, 2013 07:41AM |
Re: Network connection December 26, 2013 09:08AM |
Re: Network connection December 26, 2013 09:40AM |
Re: Network connection December 26, 2013 01:08PM |
Re: Network connection December 26, 2013 03:21PM |
