How to hold the bed down? [SOLVED] December 27, 2013 04:53PM |
Re: How to hold the bed down? December 27, 2013 07:25PM |
Re: How to hold the bed down? December 27, 2013 07:39PM |
Re: How to hold the bed down? December 28, 2013 02:42AM |
Re: How to hold the bed down? December 28, 2013 07:25AM |
Re: How to hold the bed down? December 28, 2013 07:43AM |
Re: How to hold the bed down? December 28, 2013 09:05AM |
Re: How to hold the bed down? December 28, 2013 10:33AM |
Re: How to hold the bed down? December 28, 2013 02:24PM |
Re: How to hold the bed down? December 28, 2013 04:20PM |
Re: How to hold the bed down? December 28, 2013 04:47PM |
Re: How to hold the bed down? December 29, 2013 05:08AM |
Re: How to hold the bed down? December 29, 2013 07:54AM |
Rory166
Superb pictures, what sort of camera do you use?
Rory166
I suspect the MDF pieces go the other way up than shown in picture with cardboard.
Rory166
Do you glue the MDF to the cardboard? Otherwise how is the cardboard fixed?
Rory166
I would counsel against using PLA printed part instead of MDF due to temperature.
Re: How to hold the bed down? [SOLVED] December 29, 2013 10:58AM |
Re: How to hold the bed down? [SOLVED] December 29, 2013 11:07AM |
Re: How to hold the bed down? [SOLVED] December 29, 2013 12:20PM |
Re: How to hold the bed down? [SOLVED] December 29, 2013 01:39PM |
Re: How to hold the bed down? [SOLVED] December 31, 2013 10:47AM |
Re: How to hold the bed down? [SOLVED] December 31, 2013 11:13AM |
kwikius
Just did the Range photo mount hack... Brilliant! ... Thanks
kwikius
N.B I didnt use the small recessed pieces of mdf at all. I found it works fine with just the clips straight onto the heater pcb
kwikius
I added the nuts under the MDF bed insulator to hold the heated bed securely to it. (This isnt in the Ormerod manual anywhere but saw dc42 did this so assume adding these nuts is correct. The nuts only just fit the stock screws so dont overtighten them!.)
Re: How to hold the bed down? [SOLVED] January 01, 2014 07:51PM |
Yep! I've had to use the mdf tabs now, since I decided to try out the manual levelling with the 20 mm screws.Quote
dc42
kwikius
Watch that the clips don't slide off by themselves. Swiss Clips like these are designed to lock into a hole or slot in the backing to keep them in place. That's why I used the MDF tabs.
Re: How to hold the bed down? [SOLVED] February 09, 2014 02:04PM |
Re: How to hold the bed down? [SOLVED] February 09, 2014 02:58PM |
Re: How to hold the bed down? [SOLVED] March 27, 2014 08:11AM |
Re: How to hold the bed down? [SOLVED] April 10, 2014 08:23AM |
Re: How to hold the bed down? [SOLVED] April 10, 2014 08:25AM |
Re: How to hold the bed down? [SOLVED] April 13, 2014 05:20AM |
