Printing spare parts for your Ormerod January 05, 2014 09:20AM |
Treth
@Ian (RepRapPro) as noted above there are differences between the RS build and the green build. As many of us can now print parts on the RS build are there any parts you would recommend we print to your latest standard? I am thinking of reliability/robustness here as the machine is built.
Re: Printing spare parts for your Ormerod January 05, 2014 09:26AM |
) and had only minor issues with them. I exchanged some with the current build, and only had minor problems with the extruder gears where I had to file some gears so that everything is moving very smoothly. But I also had this to do with the original extruder gears supplied in the kit. Maybe this might be a hint/ tip in the instructions?|
Re: Printing spare parts for your Ormerod January 05, 2014 11:52AM |
Re: Printing spare parts for your Ormerod January 24, 2014 11:24AM |
Re: Printing spare parts for your Ormerod June 22, 2014 09:57AM |
Re: Printing spare parts for your Ormerod June 22, 2014 11:30AM |
dtemcar
The parts are in dxf format, but if you save the file as dxf, what is saved is actually the html code
Re: Printing spare parts for your Ormerod June 22, 2014 11:53AM |
dc42
I think you need to follow the link and then use the Raw button, just as for downloading the firmware. Or download the whole file tree as a zip and extract the files you need.Quote
dtemcar
