Slic3R call in Pronterface gives error January 19, 2014 02:25PM |
Re: Slic3R call in Pronterface gives error January 19, 2014 02:57PM |
Re: Slic3R call in Pronterface gives error January 19, 2014 04:31PM |
Re: Slic3R call in Pronterface gives error January 19, 2014 04:50PM |
Re: Slic3R call in Pronterface gives error January 19, 2014 05:10PM |
slicecommand: ./Slic3r/bin/slic3r $s --output $o sliceoptscommand: ./Slic3r/bin/slic3r sliceconfig: ./profiles/These are correct for a Linux installation of Slic3r, where the Slic3r folder is in the same folder as Pronterface. It will need to be changed for windows. It will need to be:
slicecommand: [Path to slic3r folder]/Slic3r/slic3r.exe $s --output $o sliceoptscommand: [Path to slic3r folder]/Slic3r/slic3r.exe sliceconfig: [leave blank, Slic3r should use it's last used options]If that doesn't help, post the EXACT contents of slicecommand, sliceoptscommand and sliceconfig, and the EXACT path to Slic3r.exe (right click on it, properties, should show the whole path) and I'll tell you what to put in.
Re: Slic3R call in Pronterface gives error January 20, 2014 09:42AM |
Re: Slic3R call in Pronterface gives error January 20, 2014 09:01PM |
