I want a thermally activated Fan January 20, 2014 05:48AM |
Re: I want a thermally activated Fan January 20, 2014 06:00AM |
Re: I want a thermally activated Fan January 21, 2014 08:58AM |
Re: I want a thermally activated Fan January 21, 2014 09:59AM |
Re: I want a thermally activated Fan January 21, 2014 10:44AM |
Re: I want a thermally activated Fan January 21, 2014 10:46AM |
Re: I want a thermally activated Fan January 21, 2014 10:58AM |
Re: I want a thermally activated Fan January 21, 2014 12:25PM |
dc42
I just had a thought. M106 Sn where n = 0 to 255 normally sets the fan to the specified PWM value. How about M106 S-1 to set it to auto?
Re: I want a thermally activated Fan January 21, 2014 12:59PM |
Re: I want a thermally activated Fan January 21, 2014 05:41PM |
Re: I want a thermally activated Fan January 22, 2014 03:23AM |
Re: I want a thermally activated Fan January 22, 2014 04:11AM |
iamburny
It cant be that hard to use the existing thermistor to trigger a switch/relay.
more investigation to do it think.
Matt
Re: I want a thermally activated Fan January 22, 2014 04:47AM |
Re: I want a thermally activated Fan January 22, 2014 04:52AM |
Re: I want a thermally activated Fan January 22, 2014 05:11AM |
Re: I want a thermally activated Fan January 22, 2014 05:17AM |
Re: I want a thermally activated Fan January 22, 2014 05:27AM |
Re: I want a thermally activated Fan January 22, 2014 05:50AM |
Re: I want a thermally activated Fan January 22, 2014 08:56PM |
Re: I want a thermally activated Fan January 23, 2014 03:25AM |
Re: I want a thermally activated Fan January 23, 2014 03:52AM |
Re: I want a thermally activated Fan January 23, 2014 09:24AM |
dc42
The problem I see with that approach is that the voltage at the non-ground end of the thermistor is very close to the +3.3V supply voltage at low temperatures. So you really need to have that voltage available to compare it with - and you definitely need it if you want to detect an open-circuit thermistor, which I think is a necessary safety precaution.
Re: I want a thermally activated Fan September 04, 2015 04:11PM |
Re: I want a thermally activated Fan September 04, 2015 04:13PM |
Re: I want a thermally activated Fan September 04, 2015 04:34PM |
Re: I want a thermally activated Fan September 05, 2015 02:40AM |
Re: I want a thermally activated Fan September 05, 2015 05:57AM |
Re: I want a thermally activated Fan September 07, 2015 08:52AM |
Re: I want a thermally activated Fan September 07, 2015 09:09AM |
Re: I want a thermally activated Fan September 07, 2015 10:13AM |
