Re: IR sensor readings. January 20, 2014 05:49AM |
Re: IR sensor readings. January 20, 2014 05:53AM |
Re: IR sensor readings. January 20, 2014 07:17AM |
Re: IR sensor readings. January 20, 2014 08:04AM |
Re: IR sensor readings. January 20, 2014 08:11AM |
Re: IR sensor readings. January 20, 2014 08:38AM |
Re: IR sensor readings. January 20, 2014 11:33AM |
Re: IR sensor readings. January 20, 2014 12:52PM |
nipper
@dc42
One thing ... looking very closely at the sensor board through a magnifying glass the plating doesn't appear to completely line the through hole which links the ground to the side of the board with the bits and bobs on it - there's clearly a ring of virgin green board just below the lip of the hole on the back side. Shouldn't the plating go all the way through (otherwise the ground isn't connected to anything)?
Re: IR sensor readings. January 21, 2014 08:11AM |
Re: IR sensor readings. January 21, 2014 08:15AM |
Re: IR sensor readings. January 21, 2014 10:20AM |
Re: IR sensor readings. January 21, 2014 11:21AM |
Re: IR sensor readings. January 21, 2014 12:46PM |
Re: IR sensor readings. January 21, 2014 12:52PM |
Re: IR sensor readings. January 21, 2014 12:54PM |
Re: IR sensor readings. January 21, 2014 01:10PM |
Re: IR sensor readings. January 21, 2014 01:38PM |
It's better to change the component values to reduce the sensitivity to ambient light as I did, then you can calibrate it at a lower nozzle height without it saturating. Something like 1mm nozzle height with the sensor face 1 to 1.5mm above the nozzle. Then there is no need for height adjustment of the sensor board.Quote
KimBrown
Just a thought about these IR sensors....
Ok it sort of works at one particular range.... So why don't we just mount it so that it's on a slider.
We then adjust it to it's best working range. Tighten it in place and surely it should be ok then.
Kim
Re: IR sensor readings. January 21, 2014 01:39PM |
Re: IR sensor readings. January 21, 2014 01:43PM |
KimBrown
Sounds good DC.... How do we do that then????
Re: IR sensor readings. January 22, 2014 05:52AM |
Re: IR sensor readings. January 22, 2014 05:56AM |
Re: IR sensor readings. January 22, 2014 09:36AM |
Re: IR sensor readings. January 22, 2014 11:03AM |
dmould
I've not yet looked at the datasheet for that MCU, but as a thought, where is the download boot code located? If it is in an on-chip EEPROM, a new MCU will need "factory" programming via its JTAG port (or however it's done with that MCU - different processors tend to use different techniques).
