Re: ABS help January 23, 2014 08:07AM |
Re: ABS help January 23, 2014 08:23AM |
Re: ABS help January 23, 2014 08:40AM |
Re: ABS help January 23, 2014 09:32AM |
Re: ABS help January 23, 2014 09:43AM |
Re: ABS help January 23, 2014 10:04AM |
Re: ABS help January 23, 2014 10:19AM |
dmould
KimBrown
Hot Bed Issues:-
If you are ok with electrical stuff, and not the type that cuts down 6" nails for fuses then here's a suggestion....(I'm teasing)
Re: ABS help January 23, 2014 10:47AM |
KimBrown
I wouldn't be at all surprised if the problem is the fact there is to much 'current' whizzing through the duet board.
Re: ABS help January 23, 2014 03:39PM |
KimBrown
(If you do go down this road, ensure you use a good quality MUTI strand cable i.e. flexible cable.
Kim
I am going down this road to replace the ribbon cable with some larger cross section cables. I am currently printing out a drag chain to lay the wires in so they lie neatly under the table and don't offend my eye like the ribbon cable does. Do you have a spec ( cross section/strands etc) RS etc part number that you think would be appropriate. Probably use multiple wires to increase the flexibility.
I also like your idea of using a relay to switch the power to the bed. Presumably this could allow you to use a higher voltage from a second/ replacement psu to shorten the heating time of the bed.
John
Re: ABS help January 23, 2014 03:50PM |
