Am I using slic3r to create g-codes correctly?? February 22, 2014 07:32AM |
Re: Am I using slic3r to create g-codes correctly?? February 22, 2014 07:57AM |
Re: Am I using slic3r to create g-codes correctly?? February 22, 2014 08:29AM |
Re: Am I using slic3r to create g-codes correctly?? February 22, 2014 08:53AM |
Re: Am I using slic3r to create g-codes correctly?? February 22, 2014 09:06AM |
dc42
3. Issues with small print moves when the direction is changing, fixed in some non-RRP firmware builds including my 57n-dc42 build.[/quote
Does your version allow use of the original probe, and can you set the tolerance in the config file, or an external editable file?
Re: Am I using slic3r to create g-codes correctly?? February 22, 2014 09:07AM |
KimBrown
dc42
Yes, my version allows use of the original probe in exactly the same way as before. What tolerance are you referring to?
Re: Am I using slic3r to create g-codes correctly?? February 22, 2014 09:28AM |
