Re: New firmware March 05, 2014 04:33PM |
OkQuote
dc42
I have just released version 052s-dc42 of my fork of the Duet firmware..
Re: New firmware March 05, 2014 04:55PM |
Re: New firmware March 06, 2014 03:56AM |
Re: New firmware March 06, 2014 04:11AM |
Re: New firmware March 07, 2014 12:48AM |
dc42
The hot end fan serves two functions:
1. To cool the heatsink, which in turn cools the nozzle, preventing the filament from melting too far up the nozzle;
2. To cool the work, at least when printing PLA (may not be desirable when printing ABS). For example, I think that fairly rapid cooling (or a lower extrusion temperature) is desirable when bridging.
Requirement (1) means that the hotend fan must be on all the time while the extruder is hot. The hotend/sensor board I have designed (and is currently awaiting completion of PCB fabrication) includes thermostatic hotend fan control, but only to turn the hotend fan off when the extruder is cold.
Re: New firmware March 07, 2014 01:33PM |
Serial monitor
JSON response: {"poll":["I","21.3","-1.1","0.00","0.00","0.00","0.0000"],"probe":"12","buff":900,"hx":0,"hy":0,"hz":0,"seq":28,"resp":"T:-1.1 B:21.3"} queued
HTTP request: GET /rr_poll HTTP/1.1
JSON response: {"poll":["I","21.3","-0.3","0.00","0.00","0.00","0.0000"],"probe":"12","buff":900,"hx":0,"hy":0,"hz":0,"seq":28,"resp":"T:-1.1 B:21.3"} queued
JSON response: {"poll":["I","21.3","-2.0","0.00","0.00","0.00","0.0000"],"probe":"12","buff":900,"hx":0,"hy":0,"hz":0,"seq":28,"resp":"T:-1.1 B:21.3"} queued
Re: New firmware March 07, 2014 02:39PM |
Re: New firmware March 07, 2014 02:56PM |
Re: New firmware March 07, 2014 03:17PM |
Re: New firmware March 07, 2014 04:41PM |
Re: New firmware March 08, 2014 06:03AM |
Re: New firmware March 15, 2014 04:53AM |
Re: New firmware March 18, 2014 05:10AM |
Re: New firmware March 18, 2014 06:06AM |
Re: New firmware March 18, 2014 01:46PM |
Re: New firmware March 18, 2014 03:27PM |
Re: New firmware March 18, 2014 03:34PM |
KimBrown
Hi Dave, that's an interesting Plumber Block, what are the plans for it?
Re: New firmware March 18, 2014 05:01PM |
dc42
Hi zombiepl, can you post the gcode file you were printing when this happened, or at least the last 200 or so lines?
M203 X15000 Y15000 Z300 E6000 M201 X1000 Y1000 Z10 E1000
Re: New firmware March 18, 2014 05:37PM |
dc42
Re: New firmware March 18, 2014 06:18PM |
Re: New firmware March 19, 2014 02:34PM |
Re: New firmware March 20, 2014 06:16PM |
zombiepantslol
Nonetheless, I can confirm rayhicks' observation. While printing, I've noticed the first XY movement after each layer change happens much quicker than specified in Slic3r or Cura and seems to be only limited by the firmware maximums. To reproduce this issue, limit all speeds to, say, 20mm/s in Slic3r, slice some STL file and print it.
Re: New firmware March 21, 2014 01:34PM |
Re: New firmware March 28, 2014 08:29AM |
Re: New firmware March 28, 2014 09:44AM |
Re: New firmware March 28, 2014 09:59AM |
Re: New firmware March 28, 2014 11:13AM |
Re: New firmware March 28, 2014 07:20PM |
Re: New firmware March 28, 2014 07:42PM |
Re: New firmware March 28, 2014 08:55PM |
