Tired of forgetting to turn on your bed heater? February 25, 2014 06:01PM |
M140 S[first_layer_bed_temperature] ; Set bed heater M116 ; Wait for everything (Bed temp) M104 S[first_layer_temperature] ; Set hotend M116 ; Wait for everything (Hotend temp)
Re: Tired of forgetting to turn on your bed heater? February 25, 2014 06:25PM |
Re: Tired of forgetting to turn on your bed heater? February 25, 2014 11:18PM |
Re: Tired of forgetting to turn on your bed heater? February 26, 2014 05:04AM |
KP
I'm not too keen on bed plane comp, the wear on the Z axis is bad enough without it screwing up and down continuously. I'm levelling manually with a 20mm cube I printed for calibration (that turned out to be within 0.02mm in all dimensions) instead of rolling a drill bit under the nozzle. The only issue is one corner of the glass droops by ~0.1mm. Does the plane comp cater for a twisted plane too?
