Re: Bed Clips March 03, 2014 03:03PM |
Re: Bed Clips March 03, 2014 03:40PM |
Davek0974
Hmm I'm not sure clamping the mdf under pressure will be good, it barely has the strength to stay where it's put as it is.. I'm heading more for getting shot of the wood altogether.
Re: Bed Clips March 03, 2014 04:46PM |
Re: Bed Clips March 03, 2014 05:12PM |
Re: Bed Clips March 03, 2014 06:28PM |
Re: Bed Clips March 03, 2014 06:31PM |
Re: Bed Clips March 03, 2014 06:47PM |
Re: Bed Clips March 03, 2014 06:54PM |
Re: Bed Clips March 04, 2014 05:44AM |
Re: Bed Clips March 04, 2014 05:49AM |
Re: Bed Clips March 04, 2014 07:53AM |
rayhicks
I've used kapton tape to hold my bed components together for months - it has the advantage that it binds all layers and the nozzle passes over it as if it wasn't there, I just press the layers at each corner gently together and wrap tape from glass surface round to the mdf underneath, I also tape over the exposed heater connectors if I remember to
Ray
Re: Bed Clips March 04, 2014 11:43AM |
Re: Bed Clips March 05, 2014 12:47PM |
rayhicks
Since I've thinned the cement with acetone as you suggested, I find it doesn't bubble so much (maybe I've thinned it more than you, I had only a scraping left in the pot before thinning) - normally I've just slit the tape with a stanley knife if I need to remove the glass for cleaning, but I haven't tried sticking it back on when hot,
Ray
