Help: How to center to print bed to x100 y100? March 10, 2014 04:37AM |
Re: Help: How to center to print bed to x100 y100? March 10, 2014 04:59AM |
Re: Help: How to center to print bed to x100 y100? March 10, 2014 05:24AM |
Re: Help: How to center to print bed to x100 y100? March 10, 2014 05:26AM |
Re: Help: How to center to print bed to x100 y100? March 10, 2014 06:22AM |
Re: Help: How to center to print bed to x100 y100? March 10, 2014 07:30AM |
Davek0974
No need, if you home X & Y, the centre should be around x100 y100
Re: Help: How to center to print bed to x100 y100? March 10, 2014 08:16AM |
G91 G1 Z5 F200 G90 G1 X-240 F2000 S1 G92 X0 G1 X3 F200 G1 X-30 S1 G92 X0 G91 G1 Z-5 F200 G90
G91 G1 Z5 F200 G90 G1 X-240 F2000 S1 G92 X0 G1 X3 F200 G1 X-30 S1 G1 X15 F2000 G92 X0 G91 G1 Z-5 F200 G90
Re: Help: How to center to print bed to x100 y100? March 10, 2014 10:07AM |
Re: Help: How to center to print bed to x100 y100? March 10, 2014 01:51PM |
dmould
In fact I have not done that myself, but if I am going to print a large print that nearly covers the plate, then after homing X and Y, I position the nozzle over the real bed centre (in my case "G1 X112 Y103"), and then send "G92 X100" and "G92 Y100". (It would probably work if I sent "G92 X100 Y100" but I haven't tried because I'm unsure if the firmware will take it).
Re: Help: How to center to print bed to x100 y100? March 11, 2014 08:19AM |
dc42
dmould
Yes, the firmware will take it.
Just be aware that if you are using my firmware, then it will not allow X or Y movement to negative values or values beyond the configured axis length once the axis have been homed, except when homing. So if you set the bed centre as X=100 then the "park" position of the head will be right on the edge of the bed, instead of beyond the edge of the bed. That's why I suggested telling slic3r where the centre of the bed is instead.
Re: Help: How to center to print bed to x100 y100? March 11, 2014 11:37AM |
Re: Help: How to center to print bed to x100 y100? March 11, 2014 12:53PM |
dc42
Or you could put a piece of white card on top of the homing tab to make it wider, bringing the x-homing point up to the edge of the bed.
