Hello,
Firstly, this may not be an Ormerod issue per se, but this is the machine I'm using... And I have the Ormerod Slic3r settings installed.
I've found that if I slice something in Slic3r 0.9 I can print this out OK, using the Printrun in the Software GitHub repository. However, if I try using a 1.x or GitHub/development version of Slic3r, everything looks OK until I load it up to print and at which point model looks a mess and has lines shooting way off the bed. See the attached screenshots.
I would stick with the old 0.9 version of Slic3r, but unfortunately this crashes when I try to print a new Prusa Mendel X-carriage (something about holes or not being manifold) for a broken machine.
Any ideas?
Regards,
Andrew
