Re: New firmware: temperature correction, absolute extruder moves March 18, 2014 10:15AM |
rayhicks
droftarts
Most other firmware uses pre-generated thermistor tables embedded in firmware, requiring flashing updated firmware to change the thermistor values. We can change the thermistor values on the fly, as they are calculated by the firmware. I think splitting thermistor settings out from PID settings (M301) is advisable, or the M301 command becomes rather unwieldy, particularly if you're going to add other thermistor values. I suggest using M305, as this is currently unused.
why didn't you suggest this two months ago when the issue was raised? [forums.reprap.org] or at some time over the last week when we were discussing calibration and temperature reading issues?
Re: New firmware: temperature correction, absolute extruder moves March 18, 2014 11:22AM |
droftarts
The g-code list is for a wide range of firmwares, and the Duet firmware is still rather new. So if you're documenting the extending functionality of a specific gcode, be very aware that it may confuse the hell out of other users!
Re: New firmware: temperature correction, absolute extruder moves March 18, 2014 03:18PM |
Re: New firmware: temperature correction, absolute extruder moves March 20, 2014 10:48AM |
