New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 23, 2014 06:48PM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 24, 2014 03:46AM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 24, 2014 03:05PM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 24, 2014 03:27PM |
zombiepantslol
One thing I have noticed though is that the first XY move after a layer change takes ~3 seconds before it continues, although the speed seems to be okay. Is this normal?
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 24, 2014 07:33PM |
zombiepantslol
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 25, 2014 07:32AM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 25, 2014 10:26AM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 25, 2014 10:47AM |
dc42
I'd still like to rewrite the code to generate the steps for each motor independently, but I haven't time to do that as I need to get on with revenue-generating activities right now.
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 25, 2014 01:33PM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 25, 2014 01:58PM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 25, 2014 02:18PM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 25, 2014 02:25PM |
dmould
As an addition, I'm printing another of those parts (I need 4), and I noticed that the second (solid) layer prints slower than the first layer. Which is odd because Slic3r is set to print the first layer at 80% speed - so it should be the second layer that is faster than the first.
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 25, 2014 02:27PM |
gammasistemi
Hi dc42,
just terminated my first print with 0.57w (a part with a lot of small and big circular holes)
No problems at all.
All holes are perfectly rounds and also external perimeters are very good.
My speed settings of slic3r 1.0.0RC3
60mm/s perimeters
60mm/s infill
120mm/s travel
Roberto
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 25, 2014 02:32PM |
auser
Hi dc42
which Version would you recommend currently?
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 25, 2014 02:55PM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 25, 2014 02:57PM |
dmould
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 25, 2014 03:16PM |
dc42
dmould
David, this is commanded in Leg.g. Here are some extracts:
Line 34:
G1 F2400.000 E-6.00000
G1 Z0.200 F7200.000
G1 X97.265 Y88.030 F7200.000
G1 E6.00000 F2400.000
G1 X97.995 Y87.270 E0.03650 F3360.000
1022:
G1 Z0.400 F7200.000
G1 X112.499 Y100.030 F7200.000
G1 X112.481 Y100.313 E0.00983 F1229.063
So first layer is printed mainly at F3360 (falling to 2400 for a time) and the second layer starts at F1229.063 (rising to F1720.689 a little later). Maybe a bug in slic3r 1.0RC3?
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 25, 2014 03:57PM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 25, 2014 04:05PM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 25, 2014 06:20PM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 26, 2014 08:19AM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 26, 2014 10:54AM |
dc42
Oops... I'm somewhat embarrassed to say that in release 57o-dc42 I broke the automatic bed compensation code, and it hasn't been working properly in any of my releases since then.
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 26, 2014 11:03AM |
dc42
David, perhaps you should report this issue to the developer of slic3r? As it is still a release candidate, there may be a good prospect of getting it fixed promptly.
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 26, 2014 11:04AM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 26, 2014 01:45PM |
dc42
Dave, the code as it was would behave differently depending on whether or not you homed the Z axis before running G32. If you did, then only a tiny amount of bed compensation would be applied, probably not enough to be seen. If you didn't, then the firmware would consider the first probe point to be lower (depending on your G31 setting) than it really is and the other 3 to be at almost equal heights.
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 26, 2014 02:25PM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 26, 2014 02:44PM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 26, 2014 05:50PM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 27, 2014 04:55AM |
Re: New firmware: fix for XY moves after Z moves,ultrasonic Z probe support March 27, 2014 12:10PM |
