Z-height sensor - inductive? April 01, 2014 01:56PM |
Re: Z-height sensor - inductive? April 01, 2014 02:23PM |
Re: Z-height sensor - inductive? April 01, 2014 06:37PM |
Re: Z-height sensor - inductive? April 02, 2014 04:58AM |
Re: Z-height sensor - inductive? April 02, 2014 05:04AM |
Interesting. The first method mentioned in the link was "stereoscopic vision" which is another technique I was playing around (in my thoughts) with! This or a close range triangulation method 'fused' with the modulated IR beam and the.........., could be the solution!
Re: Z-height sensor - inductive? April 02, 2014 05:12AM |
Radian
Hi Treth. The capacitive scheme has been working very well for me in the last couple of weeks, but I suspect changes in humidity are going to require more frequent recalibration than an inductive approach - which is probably the least affected by environmental variables. As things were moving surely, if a little slowly, with the other techniques I didn't want to get sidetracked by exploring yet another proximity detection solution - but now you bring it up I guess now might be the time
I would say that it's definitely viable. In the past I've used a small ferrite cored inductor in place of a crystal to clock a microprocessor at a rate that varies when brought close to a ferrous object. This wasn't required for a critical measurement so I used the CR watchdog timer as the reference timebase. However, the PIC chip I'm currently using for the capacitive sensor has secondary xtal amplifier that can clock an on-board 16 bit timer so this could be used with a LC tank leaving the microprocessor clock xtal as the timing reference. Rats, I guess I'm going to have to test it out now.
Re: Z-height sensor - inductive? April 02, 2014 06:38AM |
Re: Z-height sensor - inductive? April 02, 2014 07:03AM |
Re: Z-height sensor - inductive? April 02, 2014 10:22AM |
Radian
A couple of years ago I spent (wasted?) hundreds of hours on a project to design a powerful pulse induction metal detector. For our application even a drastically cut down version would still require a minimum amount of precision analogue circuitry so I'm pretty sure we can count it out on the grounds of cost/complexity if nothing else. My detector project showed me just how rapidly diminishing the returns are (figuratively as well as literally) when trying to increase detection by increasing field strength. It did however fork into a useful contactless battery charger for my car!
Re: Z-height sensor - inductive? April 27, 2014 05:30PM |
Re: Z-height sensor - inductive? April 27, 2014 07:05PM |
Re: Z-height sensor - inductive? April 27, 2014 07:13PM |
kwikius
Anther option is to use a z-axis position detector like for the x and y axis, either a microswitch or an opto break beam system, ideally in a dark box
regards
Andy
Re: Z-height sensor - inductive? April 27, 2014 08:11PM |
Re: Z-height sensor - inductive? April 28, 2014 02:37AM |
Re: Z-height sensor - inductive? April 28, 2014 03:04AM |
Re: Z-height sensor - inductive? April 28, 2014 03:12AM |
dc42
kwikius
regards
Andy
True, but that's only OK if the bed is level and very stable. If like me you use several different glass plates, then you really need to sense the height above the glass, not the height of a fixed switch. I have seen a picture of a microswitch on the hot end that rotated into place when needed.
Re: Z-height sensor - inductive? April 28, 2014 03:17AM |
dc42
kwikius
regards
Andy
Re: Z-height sensor - inductive? April 28, 2014 04:09AM |
Treth
Firstly very nice summary DC42.
dc42
kwikius
regards
Andy
A mechanism that can be moved below the extrude nozzle for direct contact sensing and out the way, i.e. just above the extrude nozzle height while printing does appear to have many advantages.
Having looked at various ideas and products since I built my printer (which sadly I haven't had time to use for a few months now!) my 'best' thoughts are around this simple concept.
[attachment 31710 Zheightpositionsensor.PNG]
Essentially it is a probe consisting of a none rotating shaft free to move in z direction.
The shaft has a hole which is to allow position detection by a slotted-opto.
The slotted-opto is used as an analogue sensor such that it detects the varying IR as the sensing slots moves across its own sensing axis.
The probe is held loosely on a spring attached to a small solenoid or stepper motor used to lift it clear while printing.
Obviously this is just a sketch and the probe should be in a sleeve and the slotted-opto screened from stray IR, but it should work perfectly with Daves modulated IR sensing.
The precision of the sensing is set by the mechanical distance between the tip and its sensing hole, so this should be stable and the reference point for the 3D printer is the slotted-opto mounting which will be precise. So this should be very stable.
Re: Z-height sensor - inductive? April 28, 2014 04:30AM |
kwikius
... BTW Sincere apologies I havent done any work on this. I should do something rather than just talking about it!
regards
Andy
Re: Z-height sensor - inductive? April 28, 2014 04:31AM |
Re: Z-height sensor - inductive? April 28, 2014 04:33AM |
balidey
thinking out of the box a bit....
Electrical circuit, positive print head, negative heat bed, nozzle touches, completes the circuit, set Z0.
Glass is an insulator, but I believe Kapton tape conducts, so you would need to use Kapton.
The circuit would only need power whilst sensing Z.
But could this be another option to consider?
Re: Z-height sensor - inductive? April 28, 2014 04:36AM |
Re: Z-height sensor - inductive? April 28, 2014 04:39AM |
balidey
So you did, sorry, totally missed it when I was reading.
Re: Z-height sensor - inductive? April 28, 2014 04:48AM |
Re: Z-height sensor - inductive? April 28, 2014 04:59AM |
Re: Z-height sensor - inductive? April 28, 2014 05:13AM |
I like this idea, but I think the Kapton Polyimide tape is a good insulator.Quote
balidey
I was thinking you could use the nozzle as the probe, not a separate one. Then no need to move anything or have additional hardware, just a feed to the print head, ground to the Kapton.
Re: Z-height sensor - inductive? April 28, 2014 06:56AM |
Re: Z-height sensor - inductive? April 28, 2014 07:23AM |
dc42
...The disadvantage is that power needs to be applied to the solenoid most of the time.
Re: Z-height sensor - inductive? April 28, 2014 10:17AM |
I doubt it would be at all reliable due to the presence of plastic on the nozzle preventing it from making electrical contact much of the time.Quote
balidey
Re: Z-height sensor - inductive? April 28, 2014 10:56AM |
dmould
In any case, many of the methods discussed would also not give the same height for different thicknesses of glass.
