I am out of options, probably motherboard malfunctioning April 04, 2014 07:38PM |
Re: I am out of options, probably motherboard malfunctioning April 04, 2014 09:58PM |
Re: I am out of options, probably motherboard malfunctioning April 05, 2014 02:59AM |
Re: I am out of options, probably motherboard malfunctioning April 05, 2014 04:14AM |
Re: I am out of options, probably motherboard malfunctioning April 05, 2014 04:46AM |
Re: I am out of options, probably motherboard malfunctioning April 05, 2014 06:22AM |
Sardi
...However, I will listen to your advice and purchase another SD card, this time keeping in mind that it MUST be High Speed...
Re: I am out of options, probably motherboard malfunctioning April 05, 2014 09:51AM |
dc42
Hi Sardi,
1. As Kim says, try a low capacity but high spec SD card. I use a Maplin own-brand 4Gb class 10 card. If that fails then the SD card socket on the Duet board may be faulty. Do the solder connections on the SD card socket look OK?
2. The end stop microswitch has 3 connections, unless one of them has broken off. It sounds like you are not using the correct two because the led is in the wrong state.
Re: I am out of options, probably motherboard malfunctioning April 05, 2014 10:24AM |
Re: I am out of options, probably motherboard malfunctioning April 05, 2014 10:46AM |
KimBrown
...When it goes wrong, have a coffee.... (But make sure you have allot of coffee ready when you first set out on the 3D printing Highway)........
Re: I am out of options, probably motherboard malfunctioning April 05, 2014 11:28AM |
Re: I am out of options, probably motherboard malfunctioning April 05, 2014 01:15PM |
Re: I am out of options, probably motherboard malfunctioning April 07, 2014 01:02PM |
Re: I am out of options, probably motherboard malfunctioning April 07, 2014 01:15PM |
Re: I am out of options, probably motherboard malfunctioning April 07, 2014 01:16PM |
Re: I am out of options, probably motherboard malfunctioning April 07, 2014 01:26PM |
Re: I am out of options, probably motherboard malfunctioning April 07, 2014 01:28PM |
Re: I am out of options, probably motherboard malfunctioning April 07, 2014 02:10PM |
Re: I am out of options, probably motherboard malfunctioning April 07, 2014 02:26PM |
Re: I am out of options, probably motherboard malfunctioning April 07, 2014 03:22PM |
Re: I am out of options, probably motherboard malfunctioning April 07, 2014 03:35PM |
Re: I am out of options, probably motherboard malfunctioning April 10, 2014 08:44AM |
Re: I am out of options, probably motherboard malfunctioning April 10, 2014 09:39AM |
Re: I am out of options, probably motherboard malfunctioning April 10, 2014 02:04PM |
