Re: pronterface stopping April 16, 2014 07:15AM |
Re: pronterface stopping April 17, 2014 12:33AM |
Re: pronterface stopping April 17, 2014 03:57AM |
parper101
Thanks for the tip! Where did you install the capacitor?
Re: pronterface stopping April 17, 2014 12:02PM |
Re: pronterface stopping April 17, 2014 01:24PM |
dmould
To try to reduce the amount & effect, you can try increasing the retraction speed, and/or tick the "wipe on retract" box in Slic3r that tries to move the nozzle out of the way quickly before a blob is created. If you do the latter however, be sure to install DC42's latest firmware - earlier versions had a bug that would cause the steppers to miss steps when retracting with "wipe on retract" set. Slowing down the print speed also helps reduce the effect - especially on small perimeters (slic3r allows you to set a different speed for small perimeters).
Re: pronterface stopping April 17, 2014 01:52PM |
PhilipTheMobster
After some reading, I found the following quote:
dmould
When thinking about the printer stopping, it stopped each time at the same place (don't know if it was also the same layer). Ans it is the place where the wiping happens. As this is a feature I just enabled, this could be the cause. What do you think? Apparently DC's new firmware also solves this :-) and I still haven't found it. Can somebody direct me to that?
Kind regards,
Philip
Re: pronterface stopping April 17, 2014 03:01PM |
Re: pronterface stopping April 19, 2014 03:48AM |
Re: pronterface stopping April 19, 2014 03:57AM |
papakel
Hi all, On closer investigation when my print stops and when I have Gcode debug running the stop always happens after the exicusion line has been sent to the printer and computor is waiting for the received OK echo, and no matter what I try to do, i.e pause print, resume, reset or enter code manually all that happens is a constant string of "sending M105" until the program stops responding altogether. I am at at a total loss as the machine has been working fine for a couple of months and as far as I know no settings have changed.
Re: pronterface stopping April 20, 2014 05:22AM |
Re: pronterface stopping April 20, 2014 05:30AM |
Re: pronterface stopping April 20, 2014 02:09PM |
