Printing artefacts: cause and remedy? April 17, 2014 06:20PM |
Re: Printing artefacts: cause and remedy? April 17, 2014 08:28PM |
Re: Printing artefacts: cause and remedy? April 18, 2014 03:00AM |
dc42
1. Mechanical? I don't think it can be belt slippage or a stepper motor missing steps, because there are no permanent steps in the piece. Looking at the photos of the ends, one side is more or less vertical, the other is not.
A quick check for this could be to use several different slicing engines with as close to the same settings as possible.
4. Cooling? Could it be that in the seconds after a section of perimeter has been printed, depending on the subsequent head movement the rate of cooling varies, and this in turn affects the width when the extruded filament solidifies?
When KimBrown releases the latest big blue this could be put to the test.
5. Something else?
I have noticed that a print can run perfect for a dozen prints and then churn out a disaster. Can't really explain this and have tried several different simple prints with exactly the same results. I thought it could have been something to do with if there was a draft or some environmental change but it still does it when enclosed in a controlled environment
I would be interested to know whether other users see the same thing, and whether other 3D printers display the same effect.
Re: Printing artefacts: cause and remedy? April 18, 2014 06:16AM |
Re: Printing artefacts: cause and remedy? April 18, 2014 07:22AM |
Re: Printing artefacts: cause and remedy? April 18, 2014 07:51AM |
Re: Printing artefacts: cause and remedy? April 20, 2014 03:05PM |
Re: Printing artefacts: cause and remedy? April 20, 2014 09:50PM |
Re: Printing artefacts: cause and remedy? April 20, 2014 10:30PM |
Re: Printing artefacts: cause and remedy? April 20, 2014 11:47PM |
Re: Printing artefacts: cause and remedy? April 21, 2014 05:30AM |
Re: Printing artefacts: cause and remedy? April 21, 2014 07:26AM |
Re: Printing artefacts: cause and remedy? April 21, 2014 07:48AM |
Re: Printing artefacts: cause and remedy? April 21, 2014 09:40AM |
Re: Printing artefacts: cause and remedy? April 21, 2014 11:32AM |
Re: Printing artefacts: cause and remedy? April 21, 2014 11:43AM |
Re: Printing artefacts: cause and remedy? April 22, 2014 12:31PM |
Re: Printing artefacts: cause and remedy? April 22, 2014 01:37PM |
Re: Printing artefacts: cause and remedy? April 24, 2014 05:31AM |
Re: Printing artefacts: cause and remedy? April 24, 2014 07:05AM |
Re: Printing artefacts: cause and remedy? April 24, 2014 09:35AM |
Re: Printing artefacts: cause and remedy? April 24, 2014 10:48AM |
Re: Printing artefacts: cause and remedy? April 24, 2014 11:24AM |
dc42
JMC, those look much better than mine! What settings are you using?
Re: Printing artefacts: cause and remedy? April 24, 2014 03:26PM |
Re: Printing artefacts: cause and remedy? April 24, 2014 04:47PM |
Re: Printing artefacts: cause and remedy? April 25, 2014 06:05AM |
Re: Printing artefacts: cause and remedy? April 25, 2014 07:04AM |
Re: Printing artefacts: cause and remedy? April 25, 2014 07:10AM |
Re: Printing artefacts: cause and remedy? April 25, 2014 11:21AM |
