Z bearing Cooling Fan Mount - iamburny Style April 26, 2014 02:00PM |
Re: Z bearing Cooling Fan Mount - iamburny Style April 26, 2014 02:09PM |
Re: Z bearing Cooling Fan Mount - iamburny Style April 26, 2014 02:24PM |
Re: Z bearing Cooling Fan Mount - iamburny Style April 27, 2014 09:13AM |
Re: Z bearing Cooling Fan Mount - iamburny Style April 27, 2014 12:10PM |
Re: Z bearing Cooling Fan Mount - iamburny Style April 27, 2014 01:36PM |
Re: Z bearing Cooling Fan Mount - iamburny Style April 27, 2014 03:04PM |
Re: Z bearing Cooling Fan Mount - iamburny Style April 27, 2014 03:08PM |
Re: Z bearing Cooling Fan Mount - iamburny Style April 28, 2014 07:42AM |
iamburny
I've only ever printed with PLA (avoided ABS because of the smell!) and not ever had a problem with warping, some slight lifting at the corners of large (150mm+) prints was corrected with the better adhesion (i.e. not using kapton) provided by glass and a good pva/water mix.
Matt
Re: Z bearing Cooling Fan Mount - iamburny Style May 08, 2014 11:49AM |
Re: Z bearing Cooling Fan Mount - iamburny Style May 09, 2014 03:39AM |
I am using Matt's mount at the moment and have had great success with it. Interested in your nozzle but not sure about the mounting, which original arm are you referring to because it doesn't fit Matt's. Do you have an stl for your arm.Quote
appjaws1
This mount attaches to the original arm.
Re: Z bearing Cooling Fan Mount - iamburny Style May 09, 2014 06:51AM |
Re: Z bearing Cooling Fan Mount - iamburny Style May 12, 2014 04:03PM |
PaulQuote
appjaws1
New arm for the 40mm nozzle mount. The nozzle should have fitted the original arm but it clips over the attachment instead of fitting in the middle of it.
