Setting the Z probe is mission impossible April 27, 2014 12:14PM |
Re: Setting the Z probe is mission impossible April 27, 2014 12:27PM |
Re: Setting the Z probe is mission impossible April 27, 2014 12:36PM |
Sardi
How in the hell am I suppose to get the value for the Z probe when it keeps changing??
ps before anyone asks, yes, I have DC42s sensor kit, but in order to install it I have to print something first and that I cant do because I cant get the Z probe value straight so I could move on to the bed compensation.
Re: Setting the Z probe is mission impossible April 27, 2014 12:43PM |
Davek0974
..Have you got the aluminium bed support plate? If so you should not need compensation anyway, this also greatly extends the z axis screw and nut life.
Re: Setting the Z probe is mission impossible April 27, 2014 02:04PM |
Re: Setting the Z probe is mission impossible April 27, 2014 03:18PM |
Sardi
In the meantime, while I was trying something else for the 100th time, the value jumped to 670 and is moving about 668 - 674, and I am working in a room with NO OTHER LIGHT SOURCE but the flourescent light bulb.
EDIT: I have also noticed that the Z probe value is more steady when the ATX power is turned off, the value changes much much rarely and only between 2 numbers (now 676-675)
Re: Setting the Z probe is mission impossible April 27, 2014 06:03PM |
Re: Setting the Z probe is mission impossible April 27, 2014 08:57PM |
Re: Setting the Z probe is mission impossible April 28, 2014 07:53AM |
Sardi
Thanks guys for the suggestions.
But right now the bed is not my enemy. I have managed to set a value for the Z probe in the middle of the bed, and have started printing, but something happened and after just a couple of circles the filament stoped flowing from the nozzle.
The extruder was working, bud started to kick in place as the filament got hard in the nozzle and the extruder couldnt push it anywhere, and I have no ide why that happened all of a sudden.
I am using the PLA provided with the kit, and the temperature was set to 200C.
Re: Setting the Z probe is mission impossible May 18, 2014 04:53PM |
Re: Setting the Z probe is mission impossible May 18, 2014 08:45PM |
Re: Setting the Z probe is mission impossible May 19, 2014 02:05AM |
Re: Setting the Z probe is mission impossible May 19, 2014 02:11AM |
Ecko
I Agee... I want to make my first print but can't get past this and the bed compensation... Help
Re: Setting the Z probe is mission impossible May 19, 2014 09:00AM |
Re: Setting the Z probe is mission impossible May 19, 2014 09:08AM |
Ecko
... but using the web interface is a pain. It's better using pronterface...
I set z0 using the arduino IDE- print using pronterface and the nozzle hovers 10mm off the bed..... For the circle test print (frustrating).
Re: Setting the Z probe is mission impossible May 19, 2014 09:30AM |
Re: Setting the Z probe is mission impossible May 19, 2014 09:50AM |
Re: Setting the Z probe is mission impossible May 19, 2014 03:07PM |
dc42
Ecko
Hi Ecko, why do you find using the web interface a pain? I think most of us have the opposite experience.
Re: Setting the Z probe is mission impossible May 19, 2014 04:01PM |
Ecko
I agree 168. I have just levelled the bed (as much as I can) but using the web interface is a pain. It's better using pronterface - I just have issues printing with this... There are some fields that are updated in the web interface like z probe levels that aren't present in pronterface... In a nutshell - it's getting a little frustrating..
