Why does the filament get stuck in the nozzle? April 28, 2014 05:50AM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 06:11AM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 06:26AM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 06:32AM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 06:35AM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 06:51AM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 07:06AM |
VortyZA
Had a problem during the week with that - could not even manually push the filament through or even pull it out again.
Turns out that there was a slight gap between the Bowden tube and the brass cap, and filament had melted it's way into the gap, then solidified. This could probably happen between the PTFE tube and the hot end too?
Have you tried manually extruding the filament to make sure that the extruder's hobbed gear isn't slipping on the filament? Have had that problem with inconsistent filament too.
Re: Why does the filament get stuck in the nozzle? April 28, 2014 07:14AM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 07:20AM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 07:38AM |
Yes, fan always working, air blowing through the heatsink to the other side.Quote
dc42
Is the fan working, is air blowing through the heatsink and out of the exits at the bottom of the heatsink duct
Yes, no space between the aluminium block and the heatsink.Quote
dc42
is the heatsink in good thermal contact with the aluminium block?
Just tested it with my finger, the top of the block is cold as ice, the bottom is hot.Quote
dc42
I'm wondering whether the aluminium cooling block (the one at the top of the nozzle) is getting too hot, which means that the filament will melt too far up the nozzle.
This is how the the small diameter PTFE tube looks like in the nozzle. Is it too short?Quote
dc42
Also wondering whether the small diameter PTFE tubing is missing or too short.
Re: Why does the filament get stuck in the nozzle? April 28, 2014 08:00AM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 08:08AM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 09:12AM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 09:18AM |
Sardi
No mate, didnt print a bloody thing yet. I am still trying to print out Ormaxis.g via Pronterface.
You are close on the solution, the problem is somewhere between the Bowden tube an the nozzle. I keep thinking if I put the right tube inside the nozzle since in my opinion the filament gets there, somehow gets stuck, while the tip of it gets melted and just drips on the bed.
We got 2 tubes with the kit - the thicker one (and less "see through") is the Bowden tube, and the other one is so called "smaller diameter tube" right?
EDIT:
Tried pushing it through by hand, removed the bowden tube and just pushed by hand at195C with no excessive force - same thing. The filament gets stuck somewhere somehow.
Also I have cleaned the nozzle minimum of 7 times.
Re: Why does the filament get stuck in the nozzle? April 28, 2014 09:24AM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 10:24AM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 10:26AM |
It is.Quote
dmould
Just to eliminate a possible cause, use a vernier or digital calliper to check that your filament is close to 1.75mm diameter along a large length, or as a quick check slide your spare tube over a long length to ensure it doesn't bind anywhere. If it is the RS supplied reel, I doubt that is the issue.
Yes there is a gap.Quote
dmould
It sounds like something is not assembled correctly at the hotend. Is there a good gap between the hot block and the cold block?
The cold block is cold, maybe not stone cold, a bit warmish, but def not hot as the hot end.[/quote]Quote
dmould
While touching the hot block will give you a nasty burn, you should be able to hold a finger on the cold block above without discomfort (don't try it unless you are willing to accept the risk of a burn - use a thermometer instead).
Yes, the PTFE tube was drilled far enough and cleaned several times, even with pressurized air can.Quote
dmould
You have said that you correctly drilled out the inside of the tube - but are you certain you drilled up far enough? Perhaps you used the wrong PTFE tube - I don't recall what the other one looked like (I never used it). The filament should extrude smoothly and easily with very moderate hand pressure.
dmould
If nothing is obvious, take off the nozzle and see whether filament can then be fed through very easily (cold). If so, replace the nozzle and re-assemble without the Bowden tube (everything except the tube) and after heating it up, feed some filament by hand vertically down into the nozzle to see if it flows freely in that situation.
Re: Why does the filament get stuck in the nozzle? April 28, 2014 11:14AM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 11:23AM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 12:07PM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 12:34PM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 12:53PM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 01:12PM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 01:44PM |
Re: Why does the filament get stuck in the nozzle? April 28, 2014 05:45PM |
droftarts
It is possible to get such a nozzle blockage out without dismantling the nozzle, I managed it the other day. I disconnected the Bowden tube from the extruder, with some spare filament in the end of the Bowden tube. I heated the nozzle to 200C, pushed a little, poke up the nozzle with a bit of wire, set temperature to 90C, then as soon as the temperature hits 90C on the graph, gently pull the filament out of the Bowden tube. With luck it clears down to the nozzle - though I did have to repeat the process 5 times!
KimBrown
Maybe that bit of swarf is the remains of the missing tube.... did you use a drill to try and clean it. That PTFE is real soft stuff.
At least you found the critter...
Hopefully it'll work for you now....
Re: Why does the filament get stuck in the nozzle? May 13, 2014 08:49AM |
