Black dust no more April 28, 2014 03:46PM |
Re: Black dust no more April 28, 2014 04:10PM |
Re: Black dust no more April 28, 2014 04:31PM |
appjaws1
Where did you get the brass pulley from? A great idea
Re: Black dust no more April 28, 2014 04:56PM |
Re: Black dust no more April 28, 2014 07:09PM |
Re: Black dust no more April 29, 2014 02:36AM |
michaelljunggren
I say - where did you get that aluminum part from!? I want one!
Re: Black dust no more April 29, 2014 02:47AM |
KimBrown
Well done Erik, I was going to print one tonight, but have been hesitating because I thought if it didn't run quite true, it would cause problems, but was going to use the original 10mm bearing, which was going to make the wall thickness to small.
... But I want to make one for the X-axis as well I think.....
Re: Black dust no more April 29, 2014 04:00AM |
Re: Black dust no more May 09, 2014 08:59AM |
I am going to attempt to add some aluminum to the ends as you did. To do that, the y-idler and y-motor bracket needs to be fixed up a bit. You don't happen to have scad or stl sources for that? :-)Quote
ormerod168
michaelljunggren
Made them from a piece of scrap aluminum, but I hope Dave will make these and and ad them to his offers, I'm working on it, hope he will crack before I run out of cherries ;-)
Re: Black dust no more May 09, 2014 12:53PM |
michaelljunggren
..I am going to attempt to add some aluminum to the ends as you did. To do that, the y-idler and y-motor bracket needs to be fixed up a bit. You don't happen to have scad or stl sources for that? :-)
Re: Black dust no more May 09, 2014 01:04PM |
Re: Black dust no more May 09, 2014 01:56PM |
michaelljunggren
Thank you for a very instructive set of images! Unfortunately my hardware store only had 3mm thick aluminum but either that'll do, or I'll strengthen it in some other way.
Re: Black dust no more May 11, 2014 06:05AM |
Re: Black dust no more May 14, 2014 05:30AM |
Re: Black dust no more May 14, 2014 05:58AM |
Chaisaeng
...My version using 2 639 bearing
in the center of the hub. It's dimension is 8mm OD 3mm ID and 4 mm height. This is a
tamiya 4wd bearing but i did not buy it from rc store, they are very expensive if get it from them.
Other dimension is quite the same as you did ..
Re: Black dust no more May 14, 2014 07:06AM |
Re: Black dust no more May 14, 2014 07:37AM |
ormerod168
Chaisaeng
Yes, that bearing is a better choice, will give you more outer mass to work with, 1.15mm instead of my flimsy 0.65mm
In the printed part you will have to file/cut the side guides for the belt away as they will not be needed anymore..and to get room for the pulley
Great work there, very solid looking pulley's! - will see if I can order same bearings from my usual supplier as RS now is banned in our firm
Erik
Re: Black dust no more May 15, 2014 07:22AM |
michaelljunggren
...done... I will now run a speed test. I took the opportunity to strengthen a few other things too.
Re: Black dust no more May 15, 2014 07:25AM |
Chaisaeng
You can lookup in this ebay listing. It is 639/3 2z bearing no too expensive i guess
[www.ebay.com]
Re: Black dust no more May 17, 2014 05:40AM |
Re: Black dust no more May 17, 2014 05:02PM |
Pointy
...This got me thinking. (dangerous I know) I don't have access to a lathe so came up with a printed part...
Re: Black dust no more May 18, 2014 04:38AM |
ormerod168
Pointy
Good thinking! - plenty of room for that with your fine build, me I had to work with the limited space of the original design so made it out of metal - and I can't 3D model, I have been playing around with OpenSCAD a bit but I don't think my brain likes it at all as it alway try to divert me to other things..
Look! - there's a squirrel at the lawn!...sigh, here we go again - who cares about a bloody tree rat anyway :-)
Erik
Re: Black dust no more May 18, 2014 02:59PM |
Pointy
..I love programming and thought OpenScad would be cool, but I just can't get into it. I personally use Sketchup for everything, I can import stl's to modify existing parts...
..Here's the X Idler modified in Sketchup...
And here it is printed and fitted to the Ormerod with a printed hub/pulley..
I have found Sketchup to be the easiest 3d modelling application to use, and there are so many resources and tutorials for it, that it is easy to pick up. Best of all its FREE!
Re: Black dust no more May 20, 2014 12:09PM |
Re: Black dust no more May 20, 2014 01:33PM |
Re: Black dust no more May 20, 2014 04:06PM |
Re: Black dust no more May 20, 2014 05:30PM |
appjaws1
Pointy,
Do you have the stl's of the hub/pulley and x-idler please?
Erik,
Thank you, how do you quote?
Paul
Re: Black dust no more May 21, 2014 04:01AM |
Re: Black dust no more May 21, 2014 05:41AM |
ormerod168
appjaws1
Pointy,
Erik,
Paul
Just press "quote" instead of "reply" and all the text in the message your are replying to will be quoted at the top, identifiable for the poster as a reply to his post - also, if you want to reply to just a part of the text, you can delete the irrelevant part and ad .....before and after....as to show that what you are replying to is out of context and your reply is to a part of the message only
Erik
