Re: It's nearly Summer... So I'm going Probeless May 12, 2014 07:22AM |
zombiepantslol
Heh, adding more compensation code is not a big deal, but I personally wouldn't be satisfied with that solution. Using the 623 bearing on the x carriage as a switch in combination with X axis alu replacement parts would be a much cleaner approach IMO.
Re: It's nearly Summer... So I'm going Probeless May 12, 2014 08:05AM |
dc42
..I've tried this and it didn't work. The force on the runner bearing has to decrease to zero and then the head has to rise some more before contact is lost...
Re: It's nearly Summer... So I'm going Probeless May 12, 2014 10:06AM |
Re: It's nearly Summer... So I'm going Probeless May 12, 2014 11:55AM |
dmould
..The only shortcoming I can think of is that it will be affected by the X arm twisting when the weight of the hotend is partially removed as the nozzle hits the bed....
Re: It's nearly Summer... So I'm going Probeless May 12, 2014 09:54PM |
Re: It's nearly Summer... So I'm going Probeless May 13, 2014 05:41AM |
Re: It's nearly Summer... So I'm going Probeless May 13, 2014 12:07PM |
