059-dc42 firmware released May 09, 2014 03:09AM |
Re: 059-dc42 firmware released May 09, 2014 06:44AM |
Re: 059-dc42 firmware released May 09, 2014 06:55AM |
Re: 059-dc42 firmware released May 09, 2014 08:02AM |
Re: 059-dc42 firmware released May 09, 2014 08:21AM |
Re: 059-dc42 firmware released May 09, 2014 08:30AM |
Re: 059-dc42 firmware released May 09, 2014 08:38AM |
Re: 059-dc42 firmware released May 09, 2014 11:02AM |
Re: 059-dc42 firmware released May 09, 2014 12:01PM |
Re: 059-dc42 firmware released May 09, 2014 02:43PM |
Re: 059-dc42 firmware released May 09, 2014 02:59PM |
Re: 059-dc42 firmware released May 09, 2014 03:12PM |
Re: 059-dc42 firmware released May 09, 2014 03:23PM |
Re: 059-dc42 firmware released May 09, 2014 03:31PM |
Re: 059-dc42 firmware released May 09, 2014 03:45PM |
Re: 059-dc42 firmware released May 09, 2014 04:07PM |
Re: 059-dc42 firmware released May 09, 2014 04:19PM |
Re: 059-dc42 firmware released May 09, 2014 06:04PM |
KimBrown
Oh as far as the networking goes... I've just noticed the IP address it's pinging....
[attachment 32508 Untitled3.jpg]
So it changed the 3 to a 9??????
Re: 059-dc42 firmware released May 09, 2014 06:15PM |
Re: 059-dc42 firmware released May 12, 2014 04:16AM |
Re: 059-dc42 firmware released May 12, 2014 04:24AM |
Re: 059-dc42 firmware released May 12, 2014 04:29AM |
Re: 059-dc42 firmware released May 12, 2014 04:47AM |
KimBrown
Hi Les, look in the homex/y.g files.... They set the park position after they home the HotEnd for each axis.
(Since fitting the microswitch on my X-axis, I've set mine to toggle the switch, move to the edge of the glass, and then done a G92 X0 to tell it that is the zero position.
It then uses that as it's parking spot). Hope that helps...
Re: 059-dc42 firmware released May 12, 2014 07:23AM |
Re: 059-dc42 firmware released May 12, 2014 07:34AM |
dc42
Les, if by "park position" you mean at the start and end of a print, then this is set by the custom gcode in the slic3r configuration (if you are using slic3r to generate your gcode).
Re: 059-dc42 firmware released May 13, 2014 03:54AM |
Re: 059-dc42 firmware released May 13, 2014 04:16AM |
Re: 059-dc42 firmware released May 13, 2014 05:30AM |
Pointy
Not sure if it's a bug or me being stupid again, but M109 doesn't appear to work as documented...
I have it in my z home configs and it will not proceed until both the hotend and bed reach temperature.
Re: 059-dc42 firmware released May 13, 2014 05:59PM |
Re: 059-dc42 firmware released May 13, 2014 06:03PM |
