X Axis issues
Posted by robbycar
X Axis issues
May 11, 2014 02:09AM
Well, I am so close to printing that I can nearly taste it!
Loaded v59 firmware and upgraded web interface.
Can jog all axes, and heaters work fine.
But the X axis seems to be an issue.
If I command it to go to say X100, it slowly moves but only to around X20. A getpos reports X100.
If I manually move the X axis to maximum then home the axis, it only moves to the middle of the arm.
Any ideas what could cause this behaviour?
Rob.
Re: X Axis issues
May 11, 2014 04:37AM
All fixed.
I stripped the x axis and reinstalled.
I think I just overtightened the belt.
Rob.
Re: X Axis issues
May 11, 2014 06:15AM
Hi robbycar
Glad you got it fixed - you may want to do a wheelie later :-)
[forums.reprap.org]
..and you could ad a bit more power to the step-moter with the M906 command in config.g but should not be necessary as the x-motor has very little mass to move, here's my line in the config.g, y-motor up a bit as it has more mass to move (alu bed, 4mm glass), extruder up should not be necessary any more, was from a change to Matt's heering bone gear that demanded a bit of conditioning to run freely:
M906 X800 Y1000 Z800 E1200 ; Motor currents (mA)
Erik
