Extruder drive, worn thread May 19, 2014 03:47PM |
Re: Extruder drive, worn thread May 19, 2014 03:59PM |
Re: Extruder drive, worn thread May 19, 2014 04:15PM |
KimBrown
Use an Allen screw for the replacement, as they are stronger...
Re: Extruder drive, worn thread May 19, 2014 06:52PM |
KimBrown
Re: Extruder drive, worn thread May 19, 2014 07:29PM |
jstck
..A bit curious what would cause that kind of wear. That part of the bolt just sits in the bearing, doesn't it?..
Re: Extruder drive, worn thread May 19, 2014 10:48PM |
ormerod168
... No, it rolls inside the bearings inner ring and that's the problem, ...
Re: Extruder drive, worn thread May 20, 2014 03:05AM |
ormerod168
jstck
No, it rolls inside the bearings inner ring and that's the problem, think hula hoop - it's not wear in the sense of grit making wear, the material is moved, I think the correct word is "rolled"
Erik
Re: Extruder drive, worn thread May 20, 2014 04:19AM |
Re: Extruder drive, worn thread May 20, 2014 02:25PM |
droftarts
Hi Erik, looks like you left the nyloc nut a bit loose, and it's been turning on the thread of the bolt, rather than turning the inner race of the bearing.
... If you run a 9mm drill through the drive block (gently, so it's still sized correctly for the bearings), you can build the whole large gear and filament drive assembly as one unit and push it into the extruder block as one piece..
Re: Extruder drive, worn thread May 20, 2014 02:33PM |
..After problems with inconsistent filament diameters in my RepRapPro Ormerod I made an extruder block that includes a spring for tensioning...
Re: Extruder drive, worn thread May 21, 2014 07:26AM |
Re: Extruder drive, worn thread May 21, 2014 08:23AM |
Re: Extruder drive, worn thread May 22, 2014 02:47AM |
Re: Extruder drive, worn thread May 22, 2014 04:25AM |
VortyZA
Thanks for the comments - MasonStonehenge is my 'alt' on thingiverse
I've updated the design a little last night. I'd be willing to widen the hole for the PTFE liner - just need to see if there's enough space as it is, otherwise might need the thicken the extruder slightly....
Re: Extruder drive, worn thread May 22, 2014 04:42AM |
VortyZA
I've found it's very effective for smoothing the action of a slightly inaccurate gear (10ths of a mm), it also makes cleaning the hobbed insert a LOT easier and it copes fine with differences in filament thickness.
Re: Extruder drive, worn thread May 22, 2014 06:51AM |
Re: Extruder drive, worn thread May 22, 2014 08:35AM |
bobtidey
I like this idea as well and have commented in thingiverse to see if it could also incorporate the Mr Burns extended hole size for inner PTFE tube which works really well in making the filament passage smoother.
