Auto Switch Off May 23, 2014 12:14PM |
Re: Auto Switch Off May 23, 2014 12:41PM |
Re: Auto Switch Off May 23, 2014 01:17PM |
Re: Auto Switch Off May 23, 2014 04:42PM |
Re: Auto Switch Off May 24, 2014 02:10AM |
Re: Auto Switch Off May 25, 2014 09:20AM |
Re: Auto Switch Off May 25, 2014 06:36PM |
Re: Auto Switch Off May 25, 2014 08:34PM |
Re: Auto Switch Off May 26, 2014 01:34AM |
Re: Auto Switch Off May 26, 2014 03:10AM |
Re: Auto Switch Off May 26, 2014 09:59AM |
Re: Auto Switch Off May 26, 2014 11:30AM |
KimBrown
BTW On another point, I found that both ends of the main 12V lines had started to come loose on my machine due to vibration. One end was starting to burn. I also found that the 12V lines go in quite nicely in to the screw connections when the boards are out of their enclosures. I intend to add a dab on my young Ladies nail varnish (when shes not looking) to the tops of the screws to stop it happening in future.
Re: Auto Switch Off May 26, 2014 12:10PM |
Re: Auto Switch Off May 26, 2014 12:54PM |
Re: Auto Switch Off May 26, 2014 02:40PM |
Re: Auto Switch Off May 26, 2014 04:44PM |
Re: Auto Switch Off May 26, 2014 04:56PM |
Re: Auto Switch Off May 26, 2014 07:08PM |
Re: Auto Switch Off May 26, 2014 07:54PM |
Re: Auto Switch Off May 26, 2014 10:09PM |
dc42
Kim, as I attempted to describe in my earlier message, you can have M81 power down the Duet completely. Just power the 5V supply from the 12V as usual. Then to start it up, you need a push button wired between ATX ON and ground (i.e. where the link is on the ATX power PC, and an M80 command in config.g to keep the power on when you release the push button.
You can use the G4 command to program a delay before the M81 command.
Re: Auto Switch Off May 27, 2014 01:42AM |
Re: Auto Switch Off May 27, 2014 02:19AM |
Re: Auto Switch Off May 27, 2014 04:33AM |
Re: Auto Switch Off May 27, 2014 04:59AM |
Re: Auto Switch Off May 27, 2014 05:12AM |
Re: Auto Switch Off May 27, 2014 09:26AM |
Re: Auto Switch Off May 27, 2014 10:20AM |
Re: Auto Switch Off May 27, 2014 01:02PM |
dc42
Dave, I had already checked the nature of the PS_ON signal on the Duet. It's an open drain output from a BSH105 mosfet. There is no pulldown resistor on the gate, however I would have thought that the capacitance of the mosfet should keep the gate near enough to ground for a little while, even if the SAM3X output goes to the high impedance state as it powers down.
Re: Auto Switch Off May 27, 2014 01:09PM |
Re: Auto Switch Off May 27, 2014 01:33PM |
dc42
Dave, I agree that there is probably a positive-going glitch on the gate. The reason I think a firmware fix may be possible is that the SAM3X has an option to assert the reset signal during brownout, and that might prevent the glitch.
