X-carriage in OpenScad May 29, 2014 05:48PM |
Re: X-carriage in OpenScad May 30, 2014 05:19AM |
Re: X-carriage in OpenScad May 30, 2014 06:52AM |
Re: X-carriage in OpenScad May 30, 2014 07:28AM |
dc42
..I like the idea of a grub screw or similar to lock it on to the bearing - I've had the x-carriage come off.
Re: X-carriage in OpenScad May 30, 2014 08:00AM |
ormerod168
dc42
I don't like the idea of opening the grip of the printed by pressure from a grub screw, would be better to wrap it more tightly around the bearing
BTW, I printed that part solid in ABS and it shrunk to a very close fit
Erik
Re: X-carriage in OpenScad May 30, 2014 08:44AM |
Re: X-carriage in OpenScad May 30, 2014 12:17PM |
dc42
John, I kept the "vestigial structures" simply so that it would grip the bearing as well as the original does. I dare say some of them could be removed. Which side do you mean by the "front side" - the one with the nozzle mounting screw holes in it?
Re: X-carriage in OpenScad May 30, 2014 01:34PM |
Re: X-carriage in OpenScad May 30, 2014 03:12PM |
KimBrown
... I'm not a lover of the Grub Screw location, as you really need to get it at the point of just touching inside the groove, else to tight is going to open up the print around the bearing, and to slack, and the bearings still going to rattle back and forth..
Re: X-carriage in OpenScad June 02, 2014 06:48PM |
Re: X-carriage in OpenScad June 03, 2014 03:20AM |
Re: X-carriage in OpenScad June 03, 2014 03:26AM |
Re: X-carriage in OpenScad June 03, 2014 06:28AM |
Re: X-carriage in OpenScad June 03, 2014 07:08AM |
Re: X-carriage in OpenScad June 03, 2014 04:18PM |
Re: X-carriage in OpenScad June 06, 2014 03:08AM |
Re: X-carriage in OpenScad June 06, 2014 03:49AM |
jstck
Not sure if it's just in my case or a more general thing, but I think the bearing on the back of this X carriage sits just a little bit higher than the default one. If the extruder is properly seated in it's "notch", the bearing can catch on the motor..
Re: X-carriage in OpenScad June 06, 2014 05:15AM |
Re: X-carriage in OpenScad June 06, 2014 06:03AM |
Re: X-carriage in OpenScad June 06, 2014 05:12PM |
