Interim dual extruder proposal June 07, 2014 07:51AM |
Re: Interim dual extruder proposal June 07, 2014 09:02AM |
Re: Interim dual extruder proposal June 07, 2014 09:44AM |
dc42
While RRP's multi-extruder kit should be very nice, with (as far as we can tell) at least three extruders and possibly support for mixing, there is no news on when it will be available. There is the 4-nozzle Kraken head, but that is expensive and needs a lot of cables. So I'm looking at making an interim 2-nozzle head. My current thoughts are:
* Replace the aluminium heatsink block with a wider one. It would have 2 threaded holes for nozzles near the middle. The screw holes for attaching the hot end to the nozzle mount would be moved outside the screw holes used to hold all the hot end parts together (heatsink, fan etc.).
* Print a new wider nozzle mount with the screw holes in the new position.
* Fit 2 nozzles to the heatsink block, each with its own heater block, cartridge heater and thermistor. If one of the heater blocks is fitted upside down then I think there is plenty of room for this.
* Add a second extruder assembly and Bowden tube to feed the second nozzle.
* Use the Duet expansion board to run the second extruder stepper motor.
* The Duet expansion board can also drive the second heater and thermistor. However, another 6 wires to the hot end will be needed, assuming the heater wires are doubled up again. Including 4 wires for the z-probe, that's 18 wires in total from the Duet and the expansion board to the hot end. As I already have a microcontroller on the hot end, I'm thinking of doing a variant of my differential IR sensor/fan control/lighting board to monitor 2 thermistors and control 2 heaters. If I run each heater at max 50% PWM and run them in antiphase, then the maximum current will be no more than it is with a single heater. So no power supply worries, and no need for more than 4 conductors in total to provide 12V power. I would use one of the Duet serial ports to send commands to the hot end board and data back. Total 8 wires (or possibly 7) to the hot end board instead of 18. This will allow me to use just the original main loom and dispense with the sensor loom.
Possible issues I foresee:
* Is the 40x20mm fan and heatsink sufficient to handle the heat from 2 nozzles? I'm fairly confident it will be when printing PLA, but it might be marginal when printing ABS. A larger fan might be needed.
* Can I get the 2 nozzles at the same height, to within better than 0.05mm? I guess this may be an issue for the Kraken as well. Once it is assembled, the easiest way to adjust it might be be to print different nozzle mounts with the screw holes for attaching it to the x-carriage at slightly different heights, or with slots.
* When changing colours, will there be a problem with the not-in-use nozzle oozing filament? I guess I could move the head off the edge of the bed while I cool one nozzle down and heat the other up.
* When changing colours, how can I get the new nozzle to start extruding cleanly? At the start of a print, printing the skirt does this - but what about a colour change in the middle of the print?
* What else haven't I thought of?
Comments and suggestions welcome!
Re: Interim dual extruder proposal June 07, 2014 10:42AM |
Re: Interim dual extruder proposal June 07, 2014 02:10PM |
Re: Interim dual extruder proposal June 07, 2014 02:55PM |
Re: Interim dual extruder proposal June 07, 2014 04:25PM |
Re: Interim dual extruder proposal June 08, 2014 04:44AM |
Re: Interim dual extruder proposal June 08, 2014 05:05AM |
GregL
Pivoted dual filament body which holds either the A or the B filament against the hobbed drive, and the B or the A filament pressed against a brake - plus a slot for an eccentric drive
New eccentric drive to hold the pivoted filament body against one side or the other - probably with a spring involved.
Re: Interim dual extruder proposal June 08, 2014 05:10AM |
Re: Interim dual extruder proposal June 08, 2014 05:19AM |
Re: Interim dual extruder proposal June 08, 2014 08:53AM |
dc42
I like the idea of a device to push the filament against the hobbed insert, or not. I find that after my printer has sat for a few hours with the filament in the same place, the slightest movement tends to snap the filament inside the extruder. Relaxing the pressure pushing the filament against the hobbed insert might avoid this.
Re: Interim dual extruder proposal June 08, 2014 10:19AM |
Re: Interim dual extruder proposal June 08, 2014 04:07PM |
Re: Interim dual extruder proposal June 08, 2014 05:25PM |
dc42
Re: Interim dual extruder proposal June 08, 2014 05:27PM |
jstck
dc42
Has that happened to you with different kinds of filament? I have had a few different kinds (generally "whatever's cheapest" from a couple different resellers) left for a day or two, and never had filament snap in the extruder. Or might it be that the extruder is just a lot tighter or something?
Re: Interim dual extruder proposal June 09, 2014 06:29AM |
Re: Interim dual extruder proposal June 09, 2014 09:06AM |
JMC
My concept and dont laugh is to fix each hot end to a curved support so that when not extruding the surplus nozzles are up and away from the print, a bit like the multiple lenses on a compound microscope where you rotate the lense you need in to position.
Challenges with this concept are:
The need to run a heating eliment and thermoresistor for each hot end
I am not shore weather the software can be adapeted to only use one extruder, not require an offset for multiple heads and weather a PWM signal can be use to signal a swap between filements.
(off topic is there a spell checking function on this fourum)
Re: Interim dual extruder proposal June 09, 2014 09:17AM |
VortyZA
One of the things I like the most about dual extruders is the ability to print all complicated support with the water soluble PVA - that wouldn't obviously work with a single nozzle.
Re: Interim dual extruder proposal June 09, 2014 02:23PM |
dmould
VortyZA
I don't see why not. You would need a sacrificial column somewhere where a few mm can be extruded after changing material on each layer to clear the hotend of the previous material. If the slicer software cannot support such a column, I am sure it could be put into firmware - just add a command to notify the firmware of the place and size of two columns. The slicer software would need to print all of one material on each layer before switching to the other material, and the firmware could then cause the head to go to the relevant column and extrude a nozzle's worth of material after each change.
Dave
(#106)
Re: Interim dual extruder proposal June 09, 2014 03:39PM |
Re: Interim dual extruder proposal June 10, 2014 03:07PM |
Re: Interim dual extruder proposal June 10, 2014 04:00PM |
Re: Interim dual extruder proposal June 14, 2014 09:17PM |
