bulges in my print - NinjaFlex June 28, 2014 05:37PM |
Re: bulges in my print - NinjaFlex June 28, 2014 06:55PM |
Re: bulges in my print - NinjaFlex June 29, 2014 10:56AM |
Re: bulges in my print - NinjaFlex June 30, 2014 04:46AM |
Re: bulges in my print - NinjaFlex June 30, 2014 06:33AM |
Re: bulges in my print - NinjaFlex June 30, 2014 10:43AM |
Re: bulges in my print - NinjaFlex July 01, 2014 02:26AM |
Re: bulges in my print - NinjaFlex July 01, 2014 03:37AM |
Re: bulges in my print - NinjaFlex July 01, 2014 08:00AM |
VortyZA
That's interesting - I would also have thought you'd need more retraction than normal due to the compression in the Bowden tube.
I must get a hold of some of this stuff - sounds interesting! How compressible / stretchable is it? Similar to silicon glue? More like an eraser?
Re: bulges in my print - NinjaFlex July 01, 2014 09:24AM |
dmould
What I meant was that it has greater extruder lag, so retractions and re-starts are effectively time-delayed - you get a blob at the point it retracts and then no extrusion for a while after it starts printing again...
Re: bulges in my print - NinjaFlex July 01, 2014 10:01AM |
dmould
VortyZA
What I meant was that it has greater extruder lag, so retractions and re-starts are effectively time-delayed - you get a blob at the point it retracts and then no extrusion for a while after it starts printing again, so you are usually better off with no retraction and live with the stringing, though that depends on the shape you are printing. It is extremely flexible - I estimate about the same as silicon sealant. I printed a couple of camera lens caps, which work better than the usual lens caps - they are soft so no risk of scratching, and I tapered the part that goes around the lens barrel so that its elasticity grips it more tightly than normal caps and it won't fall off.
In case it's of interest I've attached the simple SCAD file to make a lens cap - it is parametric so you can alter the dimensions to suit any lens.
Dave
(#106)
dc42
I am hoping to implement variable extruder lead time in a future version of my firmware fork - but first I need to catch-up with RRP's 0.78 that they have in testing.
Re: bulges in my print - NinjaFlex July 01, 2014 10:16AM |
Re: bulges in my print - NinjaFlex **SOLVED** July 04, 2014 05:06AM |
Re: bulges in my print - NinjaFlex **SOLVED** July 04, 2014 05:42AM |
Re: bulges in my print - NinjaFlex **SOLVED** July 04, 2014 06:27AM |
Re: bulges in my print - NinjaFlex **SOLVED** July 04, 2014 10:19AM |
colsenfoto
My next experiment will be high quality IGUS sliding plastic bearings. My original roller bearings are beginning to show considerable sticktion.
Best regards,
Carsten
Re: bulges in my print - NinjaFlex **SOLVED** July 04, 2014 11:55AM |
Re: bulges in my print - NinjaFlex July 07, 2014 05:32AM |
Re: bulges in my print - NinjaFlex July 08, 2014 04:00PM |
