Problem building dc42 firmware in Eclipse July 02, 2014 05:17AM |
Re: Problem building dc42 firmware in Eclipse July 02, 2014 05:37AM |
Re: Problem building dc42 firmware in Eclipse July 02, 2014 06:52AM |
jstck
I think the purpose of the ArduinoCorePatches files it to copy them in over the existing ones to get the required functionality.
Re: Problem building dc42 firmware in Eclipse July 02, 2014 07:00AM |
Re: Problem building dc42 firmware in Eclipse July 03, 2014 03:56AM |
Re: Problem building dc42 firmware in Eclipse July 03, 2014 04:28AM |
Re: Problem building dc42 firmware in Eclipse August 10, 2014 07:15PM |
dc42
jstck
That's correct. Those files are based on Arduino 1.54 so you may need to change them if you are using a more recent Arduino core.
Another change you need to make is to change the C and C++ compiler optimization setting from -Os to -O3 (or you could use -O2 if you want to use a little less program space).
I'm hoping to start (and maybe finish) merging RRP's 0.78 test version into my fork at the weekend.
