Re: Adding Multi extruder support - howto July 16, 2014 07:33AM |
Re: Adding Multi extruder support - howto July 16, 2014 09:58AM |
Re: Adding Multi extruder support - howto July 16, 2014 11:42AM |
Re: Adding Multi extruder support - howto July 16, 2014 01:11PM |
Re: Adding Multi extruder support - howto July 17, 2014 07:02AM |
Re: Adding Multi extruder support - howto July 17, 2014 07:50AM |
Re: Adding Multi extruder support - howto July 17, 2014 08:42AM |
Re: Adding Multi extruder support - howto July 17, 2014 09:09AM |
Re: Adding Multi extruder support - howto July 17, 2014 09:27AM |
dc42
H Paul, it looks like you have added wings to the duct part. I suggest you paint the outside of the one on the right in the picture black. Otherwise, when you fit the differential LED hot end board, the wing is likely to reflect light from the IR emitters into the phototransistor.
Re: Adding Multi extruder support - howto July 17, 2014 01:02PM |
Re: Adding Multi extruder support - howto July 17, 2014 01:18PM |
appjaws1
Well I am well on my way to 2 nozzle printing.
I have just finished assembling the hot-end. It was a bit fiddly because you can't follow the on-line instructions for the ormerod hot end because you can't rotate the heater blocks. So to fit, you have to fit the nozzle onto the block and screw it down so that you can screw the nozzle into the aluminium cooling block whilst keeping the heater block still, making sure you have enough nozzle remaining to fit the brass nut correctly.
The picture shows the new aluminium cooling block made by DaveK - Thank you, with my one piece, 2 vents hot end
[attachment 36744 2-nozzle-hot-end.png]
Re: Adding Multi extruder support - howto July 17, 2014 03:17PM |
Re: Adding Multi extruder support - howto July 17, 2014 04:38PM |
Re: Adding Multi extruder support - howto July 17, 2014 05:03PM |
Re: Adding Multi extruder support - howto July 17, 2014 06:04PM |
colsenfoto
Hi dc42,
I tried printing with my three-nozzle setup yesterday, but never got off the first layer. One of the nozzles was constantly ripping the print off the bed. Going from 2 to 3 nozzles only makes the problems you described even worse
This guy has some very interesting posts down the blog about rebuilding a Stratasys hot-end - lots of pictures: [feedly.com]
They can retract the support-filament nozzle a little bit. I guess it's in order to avoid the problems, you (and me also) ran into.
I have made a my own 2-nozzle aluminium-bar based on your description, so now I just need to find and print your fan-duct and modified hot-end-mount. Fitting three nozzles under iamburney's fan-duct was a pain in a certain part of the body
By the way, I have a lot of noise on my temperature measurements via the extension-board also. I hope to get the time to do some oscilloscope-noise-hunting some day.
:-) Carsten
Re: Adding Multi extruder support - howto July 18, 2014 05:25AM |
Re: Adding Multi extruder support - howto July 21, 2014 04:54PM |
Re: Adding Multi extruder support - howto July 22, 2014 06:20AM |
Re: Adding Multi extruder support - howto July 22, 2014 06:29AM |
Re: Adding Multi extruder support - howto July 22, 2014 07:37AM |
Re: Adding Multi extruder support - howto July 22, 2014 08:47AM |
appjaws1
Thank you David,
Wish me luck when I switch on.
Paul
Re: Adding Multi extruder support - howto July 22, 2014 12:25PM |
appjaws1
I've just finished installing the boards into my new printed enclosure and was just about to put all the connections back when I realised that I didn't mark the connection for the blue and white sensor cables.
I need to connect the white wire to the pin marked AD14 and the blue wire to AD12 on the X4 board, so I have connected a ribbon cable to the X4 board and intend to use the other end for this and any future connections. The only problem is I forgot to mark the ribbon cable and don't really want to dismantle the enclosure again.
So is there a Duet X4 schematic anywhere so I can work out the correct connection?
Paul
Re: Adding Multi extruder support - howto July 22, 2014 01:41PM |
appjaws1
Re: Adding Multi extruder support - howto July 22, 2014 02:32PM |
Re: Adding Multi extruder support - howto July 22, 2014 04:48PM |
muggi
appjaws1
i also get this 2 - noozle heatsink block. Do you have a moddified scad file or a SCL file for this?
Attached is my amended hot-end 2 vents and my 2 nozzle mount.
Hope that helps
appjaws - Core XYUV Duet Ethernet Duex5
firmware 3.1.1 Web Interface 3.1.1
Ormerod 1-converted to laser engraver, Duet wifi
OpenSCAD version 2020.07
slic3r-1.3.0, Simplify3D 4.1.2, Cura-4.4.1
Re: Adding Multi extruder support - howto July 22, 2014 06:10PM |
Re: Adding Multi extruder support - howto July 22, 2014 11:30PM |
dc42
I considered mounting the X4 next to the Duet like that, but I didn't like the idea of having such a tall enclosure, or cables going to the top of it. So I've taken bobtidey's enclosure design here [forums.reprap.org] and adapted it to accommodate the Duet and X4 boards back-to-back.
I will attach the cables to the X4 first, using the screw terminals to keep the profile low, then fit the X4 to the enclosure component side down. Then I will fit the Duet on top of it in the usual way.
Normally, connecting the Z probe wires would be a problem with this arrangement, because one or two of them would be connected to the expansion connector on the X4, so a low-profile mounting would be needed or the X4 stood off further from the base of the enclosure. However, I already epoxied an extra 3-way header to the bottom of my Duet board for the Z probe to reduce noise pickup from the switching regulator, so that won't be a problem for me.
Re: Adding Multi extruder support - howto July 23, 2014 02:31AM |
Re: Adding Multi extruder support - howto July 23, 2014 03:10AM |
Re: Adding Multi extruder support - howto July 23, 2014 04:55AM |
dc42
Paul, you appear to have defined both tools to use the same extruder i.e. D0. Change tool 2 to use D1. Also check you are using web interface 0.98 and firmware 0.78e-dc42. The erratic temperature reading for heater 2 is normal unfortunately, see my earlier post.
