New experimental firmware 0.78c-dc42 July 15, 2014 10:47AM |
Re: New experimental firmware 0.78c-dc42 July 15, 2014 12:52PM |
Re: New experimental firmware 0.78c-dc42 July 15, 2014 01:30PM |
zombiepantslol
- Would it be possible to move the layer height box from the settings page to the print status?
zombiepantslol
- When the page is reloaded on another device, it would be great to see the current print status. I wanted to check this already, but I haven't had time to do this yet. Maybe I'll do this later.
Re: New experimental firmware 0.78c-dc42 July 15, 2014 03:35PM |
Re: New experimental firmware 0.78c-dc42 July 16, 2014 10:00AM |
dc42
If you add the following line in the slic3r start gcode than layer height determination is automatic, and is displayed on the print status page:
; layer_height = [layer_height]
dc42
That would need quite a lot of work. At the start of a print, the web interface requests the fileinfo, from which it gets the object height, filament required, and layer height (if available). The web interface also monitors changes in the reported absolute extruder position, from which it works out the filament consumed since the start of the print. To make this info available on a newly connected web interface, you would need to:
1. Report the name of the file being printed, so that the new browser session can display it and query the fileinfo;
2. Have the firmware track the filament consumption since the start of the print, instead of the web interface tracking it.
Re: New experimental firmware 0.78c-dc42 July 23, 2014 03:20PM |
Re: New experimental firmware 0.78c-dc42 July 23, 2014 03:59PM |
Re: New experimental firmware 0.78c-dc42 July 23, 2014 05:37PM |
Re: New experimental firmware 0.78c-dc42 July 23, 2014 05:46PM |
jstck
dc42
However, you also need to add a resistor on the Duet board, between TR7 gate and source.
I do? I have been using this feature for a while, but have no extra resistor there. I have had no issues though, what could malfunction if I do not have that resistor?
Re: New experimental firmware 0.78c-dc42 July 23, 2014 06:20PM |
