Re: External fans August 29, 2014 04:50PM |
Re: External fans August 30, 2014 07:07AM |
Re: External fans August 30, 2014 08:52AM |
Re: External fans August 30, 2014 12:51PM |
dc42
If the fan is running all the time, then either the 2N7000 is faulty (e.g. damaged by static), or the fan interface needs something other than an open-drain drive. You have already said that there is 3.4V on the brown wire when it is disconnected, so the fact that you are now measuring 0V suggests a shorted 2N7000. If you disconnect the brown wire from the 2N7000, then the fan should run at max speed with the brown wire open circuit and at minimum speed with it connected to ground. If that is the case, try a new 2N7000. Make sure it is supplied to you in antistatic packaging. To protect it from static, connect the gate to the source until you have finished wiring it to the Duet.
Re: External fans August 30, 2014 01:10PM |
Re: External fans August 30, 2014 01:29PM |
Re: External fans August 31, 2014 09:18AM |
dc42
FWIW in my testing I have the fan black and red wires connected to the pins immediately above the pins that the standard hot end fan (pink and black wires in the hot end loom) are connected to. The lowest fan speed is obtained with M106 S30. Going to S20 or below makes the fan speed up again.
Re: External fans August 31, 2014 10:40AM |
appjaws1
Still confused.
The pin above the black hot end wire is the pin you said I should use as the ground pin, that would make the source and gate connected together.
If you can spare a little time could you please draw a simple wiring diagram.
appjaws1
Do you think the BC 337 transistor that you recommended would switch faster than the 2N7000 mosfet?
Re: External fans August 31, 2014 02:50PM |
Re: External fans September 01, 2014 07:24AM |
MrCrispi
Can someone please explain for me why this form of control is advantageous over simply controlling the fan with a simple M106 Sxx command? I have the same fans as @appjaws1 and control them with a M106 ommand from S185 which just gets them moving, through to S255 where you could clear a garden full of leaves with them I'm sure I must be missing something important and am keen to further upgrade when it confers an advantage - thanks for any insight
Re: External fans September 01, 2014 07:29AM |
Re: External fans September 01, 2014 08:57AM |
Re: External fans September 01, 2014 10:01AM |
Re: External fans September 01, 2014 02:25PM |
Re: External fans September 01, 2014 04:00PM |
Re: External fans September 01, 2014 04:37PM |
MrCrispi
Hi @appjaws1 - your .scad file for the x-idler-bracket appears to actually trying to import "X Idler Hub Bracket.stl" which isn't a standard Ormerod part, and changing the name to "x-idler-bracket.stl" doesn't fix it in your .scad file - could you have a quick look at your file please?
Also when producing the arms - type 1 works absolutely fine, but types 2 & three produce the attached when I try it if amended as per your parameters - what am I doing wrong here?
Many thanks
Re: External fans September 01, 2014 06:58PM |
Re: External fans September 02, 2014 04:59PM |
Re: External fans September 02, 2014 05:08PM |
Re: External fans September 02, 2014 06:10PM |
jstck
My guess is that the M106 command is executed right away, while the G1 commands are queued up / buffered, so the M106 is then done "too early" relative to the moves. Can this be the case?
Re: External fans September 02, 2014 06:26PM |
