Question about setting Z axis to zero button. August 07, 2014 04:01AM |
Re: Question about setting Z axis to zero button. August 07, 2014 05:54AM |
Re: Question about setting Z axis to zero button. August 08, 2014 08:01AM |
Re: Question about setting Z axis to zero button. August 20, 2014 10:39PM |
Re: Question about setting Z axis to zero button. August 21, 2014 02:19AM |
sevenljy
Could you tell me where the standard IR Z probe is?
Re: Question about setting Z axis to zero button. August 21, 2014 08:54AM |
cannibalistic_cow
Personally after a print I just zero X and Y then set Z to 5, that way when I turn the printer back on the next day I just send the G code to manually set x0 y0 z5.
It doesn't help for initial config, but I've had no problems so far.
If I haven't used the printer in a while I do double check though just to make sure it did stay at 5.
