Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 31, 2014 01:35AM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 31, 2014 03:27PM |
M111 S0 ; Debug off
M550 PMy RepRapPro Ormerod ; Machine name (can be anything you like)
M551 Preprap ; Machine password (currently not used)
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
M552 P192.168.5.33 ; IP address
M553 P255.255.255.0 ; Netmask
M554 P192.168.5.1 ; Gateway
M555 P2 ; Set output to look like Marlin
G21 ; Work in millimetres
G90 ; Send absolute corrdinates...
M83 ; ...but relative extruder moves
M906 X800 Y1000 Z800 E1000 ; Set motor currents (mA)
M563 P1 D0 H1 ; Define tool 1
G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
M92 E420 ; Set extruder steps per mm
M558 P1 ; Use an unmodulated Z probe
G31 Z0.7 P650 ; Set the probe height and threshold
M557 P0 X60 Y0 ; Four...
M557 P1 X60 Y165 ; ...probe points...
M557 P2 X222 Y165 ; ...for bed...
M557 P3 X222 Y0 ; ...levelling
M556 S78 X0 Y0 Z0 ; Put your axis compensation here
M201 X800 Y800 Z15 E1000 ; Accelerations (mm/s^2)
M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min)
M566 X600 Y600 Z30 E20 ; Minimum speeds mm/minute
G21 ; set units to millimeters
M107
M190 S80 ; wait for bed temperature to be reached
M104 S230 ; set temperature
T1; Select extruder
M109 S230 ; wait for temperature to be reached
G90 ; use absolute coordinates
M83 ; use relative distances for extrusion
G1 F1800.000 E-1.00000
G1 Z0.400 F3600.000
G1 X74.237 Y71.612 F3600.000
G1 E1.00000 F1800.000
G1 X75.737 Y70.112 E0.25951 F600.000
G1 X77.629 Y68.781 E0.28292
G1 X80.500 Y68.139 E0.35991
G1 X119.500 Y68.139 E4.77103
G1 X121.778 Y68.536 E0.28292
G1 X124.263 Y70.112 E0.35991 F600.000
G1 X125.763 Y71.612 E0.25951
G1 X127.093 Y73.503 E0.28292
G1 X95.696 Y76.623 E0.13316
G1 X96.010 Y76.474 F3600.000
G1 X96.734 Y76.174 E0.09078 F600.000
G1 X118.664 Y76.174 E2.53963
G1 X118.936 Y76.236 E0.03228
G1 X120.000 Y77.299 E0.17422
G1 X2 Y190; park the machine
M0; stop
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 31, 2014 03:32PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 31, 2014 04:28PM |
zombiepantslol
djar, have a look at M301 in conjunction with the 'S' parameter: [forums.reprap.org]
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 31, 2014 05:33PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 31, 2014 05:48PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 September 03, 2014 02:32PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 September 03, 2014 05:16PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 September 04, 2014 02:16AM |
