Dc42 Sensor Board proximity issues Kapton October 04, 2014 03:42AM |
Re: Dc42 Sensor Board proximity issues Kapton October 04, 2014 04:14AM |
Re: Dc42 Sensor Board proximity issues Kapton October 04, 2014 09:46AM |
dc42
Muggi, when you were using the permanent print plate, what X height were you using in your G31 command? Also, when the nozzle is just touching the bed, how high above the edge of the bed is the bottom edge of the sensor board?
I suspect one of the following:
1. The board is mounted too high above the nozzle. The edge of the board should be between 1mm and 2mm above the tip of the nozzle.
2. The board is not perpendicular to the bed.
3. The board is triggering at too low a height. This could be because the phototransistor or one of the IR LEDs has been bent. A few boards in the first batch I shipped also had low trigger heights that I now consider unacceptable.
Re: Dc42 Sensor Board proximity issues Kapton October 04, 2014 10:39AM |
Re: Dc42 Sensor Board proximity issues Kapton October 04, 2014 11:35AM |
Re: Dc42 Sensor Board proximity issues Kapton October 04, 2014 01:03PM |
Re: Dc42 Sensor Board proximity issues Kapton October 05, 2014 09:56AM |
Re: Dc42 Sensor Board proximity issues Kapton October 05, 2014 12:55PM |
