Problems after firmware upgrade October 08, 2014 10:31AM |
G91 G1 Z5 F200 G1 X20 F2000 G90 G92 Y0 G1 Y250 F2000 S1 G92 Y200 G1 Y197 F200 G1 Y250 S1 G92 Y200 G1 Y0 F2000 G91 G1 X-20 F2000 G1 Z-5 F200 G90
G91 G1 Z5 F200 G90 G1 X-240 F2000 S1 G92 X0 G1 X3 F200 G1 X-30 S1 G92 X0 G1 X60 F2000 G92 Y0 G1 Y250 F2000 S1 G92 Y200 G1 Y197 F200 G1 Y250 S1 G92 Y200 G1 Y0 F2000 G30 G1 Z5 F200 G1 X0 Y0 G1 Z0
; Configuration file for RepRap Ormerod 1 ; RepRapPro Ltd ; ; Copy this file to config.g if you have an Ormerod 1. ; If you are updating a config.g that you already have you ; may wish to go through it and this file checking what you ; want to keep from your old file. ; M111 S0 ; Debug off M550 PMy RepRapPro Ormerod 1 ; Machine name (can be anything you like) M551 Preprap ; Machine password (currently not used) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address M552 P192.168.1.14 ; IP address M553 P255.255.255.0 ; Netmask M554 P192.168.1.1 ; Gateway M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute corrdinates... M83 ; ...but relative extruder moves M906 X800 Y1000 Z800 E800 ; Set motor currents (mA) M92 E420 ; Set extruder steps per mm M558 P1 ; Use an unmodulated Z probe G31 Z0.8 P600 ; Set the probe height and threshold (deliberately too high to avoid bed crash on setup) M556 S78 X0 Y0 Z0 ; Put your axis compensation here M557 P0 X60 Y0 ; Four... M557 P1 X60 Y165 ; ...probe points... M557 P2 X222 Y165 ; ...for bed... M557 P3 X222 Y0 ; ...levelling M201 X800 Y800 Z15 E1000 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min) M566 X600 Y600 Z30 E20 ; Minimum speeds mm/minute M563 P1 D0 H1 ; Define tool 1 G10 P1 S-273 R-273 ; Set tool 1 operating and standby temperatures
Re: Problems after firmware upgrade October 08, 2014 10:39AM |
eoiser
And when pressing the end switch manually when the bed goes wrong way does not stop it, but the LED on the motherboard does turn ON, so the switch does have connection to the board.
Re: Problems after firmware upgrade October 08, 2014 11:03AM |
Re: Problems after firmware upgrade October 08, 2014 11:10AM |
Re: Problems after firmware upgrade October 08, 2014 12:10PM |
eoiser
Ok, thats my fault, i fell out when moving it, i just assumed it to light up when clicked.
But all the other wires are correctly connected.
Re: Problems after firmware upgrade October 08, 2014 01:23PM |
Re: Problems after firmware upgrade October 14, 2014 02:04AM |
Re: Problems after firmware upgrade October 14, 2014 02:24AM |
Re: Problems after firmware upgrade October 14, 2014 02:32AM |
Re: Problems after firmware upgrade October 14, 2014 03:30AM |
Re: Problems after firmware upgrade October 14, 2014 03:40AM |
Re: Problems after firmware upgrade October 14, 2014 03:51AM |
Re: Problems after firmware upgrade October 14, 2014 06:08AM |
Re: Problems after firmware upgrade October 15, 2014 03:35AM |
