No tool selected October 15, 2014 03:41AM |
Attempting to extrude with no tool selected. Attempting to extrude with no tool selected. Attempting to extrude with no tool selected. Attempting to extrude with no tool selected. Attempting to extrude with no tool selected. Attempting to extrude with no tool selected. Attempting to extrude with no tool selected. Attempting to extrude with no tool selected. Attempting to extrude with no tool selected. Attempting to extrude with no tool selected. Attempting to extrude with no tool selected. Paused. Attempting to extrude with no tool selected. Setting hotend temperature to 0.000000 degrees Celsius. Setting temperature: no tool selected. Setting bed temperature to 0.000000 degrees Celsius.
Re: No tool selected October 15, 2014 04:45AM |
Re: No tool selected October 15, 2014 06:49AM |
Re: No tool selected October 15, 2014 07:24AM |
Re: No tool selected October 15, 2014 08:09AM |
; generated by Slic3r 0.9.10b on 2014-10-15 at 12:15:36 ; layer_height = 0.24 ; perimeters = 2 ; top_solid_layers = 4 ; bottom_solid_layers = 3 ; fill_density = 0.4 ; perimeter_speed = 20 ; infill_speed = 20 ; travel_speed = 60 ; nozzle_diameter = 0.5 ; filament_diameter = 1.75 ; extrusion_multiplier = 1 ; perimeters extrusion width = 0.85mm ; infill extrusion width = 0.87mm ; solid infill extrusion width = 0.85mm ; top infill extrusion width = 0.85mm ; first layer extrusion width = 0.48mm G21 ; set units to millimeters M107 M104 S205 ; set temperature T1 ; tools G21 ; set units to millimeters G90 ; use absolute coordinates M83 ; use relative distances for extrusion M140 S65; Set bed temperature G1 Z5 F200 ; lift nozzle G1 X2 Y50 F2000; Go to wait for warm position M116; Wait for all temperatures G10 P0 S205 R0 ; Set extruder temperature T0; Select extruder M116; Wait for all temperatures M109 S205 ; wait for temperature to be reached G90 ; use absolute coordinates M83 ; use relative distances for extrusion G1 F1800.000 E-1.00000 G1 Z0.240 F3600.000 G1 X62.550 Y94.550 G1 F1800.000 E1.00000 G1 X63.670 Y93.950 F600.000 E0.06140 G1 X102.360 Y77.960 E2.02299 G1 X103.580 Y77.590 E0.06161 G1 X104.840 Y77.470 E0.06116 G1 X113.850 Y77.470 E0.43539 G1 X115.380 Y77.650 E0.07444 G1 X116.830 Y78.190 E0.07477 G1 X118.100 Y79.060 E0.07439 G1 X136.510 Y95.060 E1.17865 G1 X137.460 Y96.070 E0.06700
Re: No tool selected October 15, 2014 08:27AM |
Re: No tool selected October 15, 2014 08:33AM |
Re: No tool selected October 15, 2014 08:35AM |
Re: No tool selected October 15, 2014 08:39AM |
Re: No tool selected October 15, 2014 08:49AM |
Re: No tool selected October 15, 2014 08:58AM |
Re: No tool selected October 15, 2014 09:02AM |
Re: No tool selected October 15, 2014 09:09AM |
Re: No tool selected October 15, 2014 09:16AM |
dc42
Now that you have posted the start of your gcode file, we can see the problem. The T1 command is in your gcode, but there is also a T0 command in the gcode later on.
Re: No tool selected October 15, 2014 09:28AM |
dc42
Now that you have posted the start of your gcode file, we can see the problem. The T1 command is in your gcode, but there is also a T0 command in the gcode later on. I think this is also in your start gcode. Go to edit the start gcode in slic3r, scroll down, and I think you will find it. You need to get rid of that T0 command.
Re: No tool selected October 15, 2014 09:42AM |
eoiser
Anyways now i get this message: Attempt to set temperatures for non-existent tool: 0.
Re: No tool selected October 15, 2014 09:46AM |
Re: No tool selected October 15, 2014 10:11AM |
Re: No tool selected October 15, 2014 10:32AM |
Re: No tool selected October 16, 2014 03:28AM |
jstck
Since it still has to contain the same information (to be convertable back and forth), I don't really see how any other representation of it could be "better" than just a nicely commented section of G-code.
