Printed Extrusion? November 15, 2014 10:02PM |
Re: Printed Extrusion? November 16, 2014 12:10AM |
Re: Printed Extrusion? November 17, 2014 07:52AM |
Re: Printed Extrusion? November 18, 2014 06:21AM |
Re: Printed Extrusion? November 18, 2014 08:44AM |
jstck
It would probably work having a printed piece (or 2-3 parts attached together) instead of the Y-axis aluminium extrusion, which is under a lot less force. It wouldn't need to look exactly the same either, as long as it has the appropriate mounts for the things that need to attach to it, and could probably be integrated with the Z axis/motor mount. I don't think it really would make sense though, as those aluminium extrusions are cheaper than just the cost of the plastic and a lot stronger. Would be interesting to see someone else test just for the sake of it though.
Re: Printed Extrusion? November 18, 2014 10:33AM |
Re: Printed Extrusion? November 18, 2014 11:55AM |
jstck
Maybe by the next millennium ...
Dave
Re: Printed Extrusion? November 18, 2014 01:52PM |
Re: Printed Extrusion? November 19, 2014 08:30AM |
Cola
Glad to hear I was not the only one that tried it. Indeed I assumed it would not function well as the Z - axis, at least on the Ormerod. Perhaps on a design where it is supported from both sides, that would remove the bearing issue. 2 vertical lengths supported by 4 lengths butting up against them at 45 degree angles forming a more traditional A frame, with the X/Z supported by smooth and threaded rods on each side carrying the load. Should be no different then the aluminum extrusion framed mendel fork.
Perhaps copying the extrusion cross section exactly is not as effective as reworking it a little, maybe change the internal angle of the slots on 2 sides so it could be printed horizontally, that would ensure one surface would be nice and flat.
As long as the real thing remains cheaper and more accessible, than the printed I see no real benefit with the exception being in lines with the reprap philosophy of being as printable as possible. I will continue to pursue this for my own amusement.
-Cola
Re: Printed Extrusion? November 19, 2014 09:47AM |
dmould
Yes, printed flat it would be a lot stronger and may even work for the Z beam. But as you say, it would be better if the X-axis were supported at both ends. I recently came across this kit, which was being offered for £400 a couple of years ago (I wish I'd seen it then) - I have no idea whether it is still available, though as the full BOM is provided it would not be too difficult to source/make the parts if it is no longer offered as a full kit. [hydraraptor.blogspot.co.uk]
It looks like a very well thought-through design that I am very tempted to build, and it would probably work with a Duet controller (I'm not sure whether the two Z motors could be simply wired in parallel?). I have come to the conclusion that the Bowden extruder of the Ormerod is a design weakness that somewhat limits the quality of the parts it prints, and am keen to try a printer that has a different arrangement. It is doubtful that an X-arm that is supported only at one end could support the weight of an extruder, so I have abandoned the idea of modifying the Ormerod in favour of building a different printer from scratch.
Dave
Re: Printed Extrusion? November 19, 2014 12:42PM |
Cola
I agree about the extruder, I have a e3D V6 hot end I was going to use for my next build. I was originally using the Ormerod as my base the the more the idea came together in my head the more I looked at various Mendel based designs, Mendel Max mostly due to its all extruded frame design. I would also like to use the Duet Board, If I recall correctly RRP Ian said somewhere that the firmware would need to be modified to use a limit switch in the Z-axis or one could always use the probe on a new design with no changes. As for 2 Z motors, It should be no issue I believe the Steper drivers on the Duet are rated for 2A of current. On the Ormerod it set in the config.g to use only 800mA on the Z.
-Cola
Re: Printed Extrusion? November 19, 2014 02:48PM |
Ormerod187
jstck
Dave
nice dream.... are you sure it's enough thousand years?
Re: Printed Extrusion? November 19, 2014 04:41PM |
Re: Printed Extrusion? November 20, 2014 07:37AM |
dmould
Ormerod187
jstck
Dave
At the pace technology is advancing I do not believe it is too optimistic, and may be on the low side. Consider that the invention of the first electronic component (the thermionic diode) was in 1904, and look at how much progress was made in the field of electronics during the 1000 years that followed. Everyday technology of 2004 would be considered nothing less than magical to a person in 1904.
Dave
Re: Printed Extrusion? November 20, 2014 07:59AM |
Re: Printed Extrusion? November 20, 2014 11:49AM |
Re: Printed Extrusion? November 20, 2014 12:00PM |
reprapprochina
Dear Dario: I came across your photos file in dropbox, they are so impressive. It seems you have a small factory of OM 3D printers. May we use some photos for our website to show your printed items and demonstrate the potential capability of RepRapPro printers?
Many thanks,
Re: Printed Extrusion? November 20, 2014 12:07PM |
Ormerod187
reprapprochina
Many thanks,
Hi reprapprochina,
feel free to use my photos.
Regards
Dario
