cleaning the bed November 27, 2014 12:03PM |
Re: cleaning the bed November 27, 2014 12:32PM |
Re: cleaning the bed November 27, 2014 12:38PM |
Re: cleaning the bed November 27, 2014 02:16PM |
razzadazzas
my bed has kapton tape on it which came with the build and is layed across the glass with a very slight over lap
ive ordered 200 mm wide tape so replacing will be a case of laying one main strip and then one strip of the thinner tape so i dont get the lines on the botom of my work
is it correct that the tape can stay there for as many uses as you want provided its not damaged?
but my main question is am i cleaning the bed too much, i poor a drip of acetone on the be then use kitchen towel to wipe it across the bed, my problem is i know its good to have your work piece stick o the bed but some of min are irremovable what every one consensus
Re: cleaning the bed November 27, 2014 03:01PM |
Re: cleaning the bed November 27, 2014 04:07PM |
dc42
Recently I've used a Pritt stick (PVA glue stick) to prime the bed instead, with good results.
Re: cleaning the bed November 28, 2014 06:20AM |
Re: cleaning the bed November 28, 2014 09:48AM |
