Verbatim PLA Filament January 06, 2015 02:22PM |
Re: Verbatim PLA Filament January 06, 2015 04:35PM |
Re: Verbatim PLA Filament January 06, 2015 05:42PM |
Re: Verbatim PLA Filament January 07, 2015 01:44AM |
RoSt
..Any idea what to do to come around this?
Re: Verbatim PLA Filament January 07, 2015 03:01AM |
Re: Verbatim PLA Filament January 07, 2015 07:54AM |
Re: Verbatim PLA Filament January 07, 2015 08:52AM |
ezwul
Original white filament and previous filament bought up until now didnt break and could be left for long periods, but the latest 3x 1kg reels I have purchased from a different supplier all break at the point you mention if left over night in the extruder. So I have also moved to backing the filament out over night.
I have noticed that the new stuff is a lot more brittle than the original white test filament and previous reels I bought.
Re: Verbatim PLA Filament January 07, 2015 08:57AM |
Re: Verbatim PLA Filament January 07, 2015 09:09AM |
jamesf
I also remove filament after every session so have not seen breakage yet. Too humid here at the moment and want to keep it as dry as possible.
Do you have a link to the parts for your filament stand - I like the design?
James
Re: Verbatim PLA Filament January 07, 2015 02:36PM |
RoSt
jamesf
James
Fun that you like them.
I can put them on Thingiverse tonight and link them, and do a parts list after work tonight.
//Robert
Re: Verbatim PLA Filament January 07, 2015 03:20PM |
Re: Verbatim PLA Filament January 07, 2015 03:56PM |
Re: Verbatim PLA Filament January 07, 2015 05:46PM |
RoSt
...I didn't want a 1kg spool coming down the shelf it stands on so i put some double sided tape at each corner. (Biltema 29505)
//Robert
Re: Verbatim PLA Filament January 07, 2015 06:22PM |
Re: Verbatim PLA Filament January 08, 2015 01:00AM |
Re: Verbatim PLA Filament January 08, 2015 09:12AM |
jamesf
Thanks all for sharing your designs.
I see Visual54 uses the same workbench layout as I do
James
Re: Verbatim PLA Filament January 08, 2015 09:33AM |
dmould
That's a terrible layout! There are not nearly enough empty beer bottles for a start, and I can see a few small areas of unused work surface that could easily have been filled with some bits of discarded wire or loose nuts & bolts. There is no area of my bench that is under less than 3 layers ofjunkessential equipment. I'd show you if I could only find where I put my camera ...
Dave
Re: Verbatim PLA Filament January 09, 2015 07:44AM |
Re: Verbatim PLA Filament January 12, 2015 05:33PM |
Re: Verbatim PLA Filament January 13, 2015 04:18AM |
Re: Verbatim PLA Filament January 13, 2015 05:49AM |
Re: Verbatim PLA Filament January 13, 2015 08:51AM |
Re: Verbatim PLA Filament January 15, 2015 05:18AM |
dmould
Sardi
Looking at your filament holder designs, I must ask, is the extruder motor that strong to pull (at the start) a whole of 1kg reel?
My extruder once lifted an almost full 1kg reel off the floor when the filament got tangled, so yes.
Dave
Re: Verbatim PLA Filament January 15, 2015 07:35AM |
