First print with ABS - printbed barely reaching 110°C January 12, 2015 06:45PM |
Re: First print with ABS - printbed barely reaching 110°C January 12, 2015 07:09PM |
Re: First print with ABS - printbed barely reaching 110°C January 13, 2015 01:13AM |
Re: First print with ABS - printbed barely reaching 110°C January 13, 2015 03:47AM |
Re: First print with ABS - printbed barely reaching 110°C January 13, 2015 08:47AM |
Re: First print with ABS - printbed barely reaching 110°C January 13, 2015 10:20AM |
dmould
Note that you will have to get suitable mains and 12V connectors and print some sort of housing to cover the exposed terminals
Re: First print with ABS - printbed barely reaching 110°C January 13, 2015 03:12PM |
Re: First print with ABS - printbed barely reaching 110°C January 13, 2015 04:37PM |
Re: First print with ABS - printbed barely reaching 110°C January 14, 2015 02:38AM |
dc42
You can speed up the initial heating of the heated bed by putting a heat-insulating cover on it.
Re: First print with ABS - printbed barely reaching 110°C January 14, 2015 02:48AM |
Re: First print with ABS - printbed barely reaching 110°C January 14, 2015 03:08AM |
Re: First print with ABS - printbed barely reaching 110°C January 14, 2015 04:11AM |
Re: First print with ABS - printbed barely reaching 110°C January 18, 2015 05:09PM |
Re: First print with ABS - printbed barely reaching 110°C January 18, 2015 05:47PM |
Re: First print with ABS - printbed barely reaching 110°C January 19, 2015 07:35AM |
dc42
For ABS printing, you don't want any air blowing on the print. So block off the nozzles at the bottom of the duct, and make a hole or slot in the top of the duct to let the air out. But I guess you already know that, as you did a venting mode to the duct.
Re: First print with ABS - printbed barely reaching 110°C January 19, 2015 07:49AM |
Hi Dave[id]Quote
dmould
dc42
Yes, that was a very good mod of yours for ABS that I applied about a year ago and have been using ever since. However I think that some cooling air would be beneficial when printing bridges or overhangs, so one day I really must get around to making a Duet controlled cooling system. OTOH I don't think there is any slicing software that will automatically turn cooling on for overhangs, so perhaps I may as well go for manual control along the lines "tstone" designed.
Dave
Re: First print with ABS - printbed barely reaching 110°C January 19, 2015 08:36AM |
tstone
I think there are weight advantages in combining one cooling fan for the hotend and the workpiece combined with a
ultra leightweight servo compared to a two fan solution.
Re: First print with ABS - printbed barely reaching 110°C January 19, 2015 08:42AM |
tstone
I have found a lightweight servo of 2g which should have enough power to drive the venting flap automatically.
I think that at least in the developement version of slic3r is a cooling control implemented. So the only missing stuff
is controlling the servo from the firmware according to the cooling settings from slic3r. Controlling a servo from the duet
shouldn't be to hard, if it hasn't been done already?
Tim
Re: First print with ABS - printbed barely reaching 110°C January 19, 2015 11:28AM |
Re: First print with ABS - printbed barely reaching 110°C January 19, 2015 11:38AM |
Re: First print with ABS - printbed barely reaching 110°C January 19, 2015 12:09PM |
ormerod168
jamesf
Room temperature 15 C Erik?
I see no reason to heat up the whole house when I can regulate my temperature more efficiently and sustainable by adding hot coffee (lots of coffee!) to my internal central heating system ;-)
Erik
Re: First print with ABS - printbed barely reaching 110°C January 19, 2015 01:32PM |
dmould
A solenoid would probably be easier to implement than a servo. The Duet's 12V cooling fan output is implemented in firmware but not used in the standard Ormerod. That provides a PWM output for speed control, but so long as Slicer is set up to set the fan to be either off or 100% it will act as a simple on/off output to drive a 12V solenoid directly (put a diode across the solenoid to protect against back-EMF). RS have a variety of both push and pull action 12V solenoids - weight should not be too critical.
Re: First print with ABS - printbed barely reaching 110°C January 19, 2015 03:41PM |
dc42
dmould
If you do use a solenoid, don't forget to put a flyback diode in parallel with it.
My experience with sourcing solenoids when I was looking at a solenoid-activated Z probe was that they are much cheaper when sourced from China. Also, the suitable solenoid that I was able to source in the UK (from Farnell I think) did not include a spring, whereas the Chinese ones did. The spring was going to cost more than £2 to have manufactured as it was a standard design but not an off-the-shelf item,.
Re: First print with ABS - printbed barely reaching 110°C January 19, 2015 07:03PM |
Hi ErikQuote
ormerod168
Up to now I have used johneato's brilliant mod of the original heat sink duct
Re: First print with ABS - printbed barely reaching 110°C January 20, 2015 04:50AM |
tstone
....I would also like to have a flap thats easier to control with a servo.
I think i will aim for even larger cooling openings to have cooling maximised as this can be reduced with the the flap of my last revision.
Re: First print with ABS - printbed barely reaching 110°C January 20, 2015 04:59AM |
Re: First print with ABS - printbed barely reaching 110°C January 25, 2015 06:30PM |
Re: First print with ABS - printbed barely reaching 110°C January 26, 2015 08:00AM |
Re: First print with ABS - printbed barely reaching 110°C January 26, 2015 10:39AM |
Re: First print with ABS - printbed barely reaching 110°C January 26, 2015 01:26PM |
tstone
Hi Dave
I am fully aware that this needs firmware modifications, thats where the fun starts, right :-).
Tim
