What's going on here then..? January 13, 2015 07:22PM |
Re: What's going on here then..? January 13, 2015 07:38PM |
Re: What's going on here then..? January 13, 2015 08:28PM |
Re: What's going on here then..? January 14, 2015 01:20AM |
Re: What's going on here then..? January 14, 2015 03:36PM |
Re: What's going on here then..? January 14, 2015 06:00PM |
Re: What's going on here then..? January 15, 2015 07:06AM |
Re: What's going on here then..? January 16, 2015 10:55AM |
Re: What's going on here then..? January 16, 2015 11:36AM |
Re: What's going on here then..? January 16, 2015 12:43PM |
Re: What's going on here then..? January 16, 2015 01:45PM |
Re: What's going on here then..? January 16, 2015 03:11PM |
Re: What's going on here then..? January 16, 2015 05:06PM |
Re: What's going on here then..? January 16, 2015 05:09PM |
Re: What's going on here then..? January 20, 2015 05:57AM |
Re: What's going on here then..? January 20, 2015 06:20AM |
Re: What's going on here then..? January 20, 2015 07:07AM |
Re: What's going on here then..? January 20, 2015 08:05AM |
Re: What's going on here then..? January 20, 2015 12:44PM |
Re: What's going on here then..? January 20, 2015 02:44PM |
static65
Oh, something I just thought of! Is it possible to change which stepper driver is assigned to which axis? That way I could swap the X and Y cables over and if the problem shifts to the X axis it could indicate a duet fault?
Re: What's going on here then..? January 20, 2015 02:48PM |
Re: What's going on here then..? January 20, 2015 03:26PM |
Have to second this - I started with insufficient oil on the smooth rods and Z threaded rod. Will cause many issues.Quote
pandionx
This may be a really dumb question, but when last did you oil the smooth steel rods on your Ormerod? I had endless problems in the Z-direction, and after spending hours with polishing it with steel wool to no avail, 2 drops of 3-in-1 oil resolved my problems completely. Perhaps your Y direction rods are binding slightly, just enough to cause a problem?
Re: What's going on here then..? January 20, 2015 03:29PM |
pandionx
This may be a really dumb question, but when last did you oil the smooth steel rods on your Ormerod?...
Re: What's going on here then..? January 21, 2015 07:17AM |
