Extruder gears jamming January 17, 2015 05:54AM |
Re: Extruder gears jamming January 17, 2015 06:31AM |
Re: Extruder gears jamming January 17, 2015 08:04AM |
Sardi
Did anyone else have this kind of problem? I dont know what to check next ..
Regards,
Antonio
Re: Extruder gears jamming January 17, 2015 08:26AM |
Re: Extruder gears jamming January 17, 2015 09:26AM |
Re: Extruder gears jamming January 17, 2015 09:41AM |
Re: Extruder gears jamming January 17, 2015 02:23PM |
Re: Extruder gears jamming January 17, 2015 04:57PM |
Sardi
I dont belive it would be a temperature issue, the jaming is not consistent, it comes and goes randomly.
However, It seems everything is ok now.. I have cleaned the nozzle 6 times by extracting the filament and since then there was no jamming of the gears.
Monty Python and the Holy Grail (sort of)
...Then, shalt thou clean the nozzle six times, no more, no less. six shalt be the number thou shalt clean the nozzle, and the number of the cleaning shalt be six. seven times shalt thou not clean, nor either five, excepting that thou then proceed to six. eight is right out...
Re: Extruder gears jamming January 17, 2015 10:17PM |
Sardi
Thanks guys.
I have just cleaned the nozzle three times following the instructions on RepRap Troubleshooting page.
One thing is for sure - the gears dont start to jam until the filament reaches the nozzle, should I dismantle the hot end and inspect the nozzle for debris by hand?
It stopped jaming all of a sudden. Will try a print and see if the problem is fixed.
Re: Extruder gears jamming January 18, 2015 06:39AM |
Re: Extruder gears jamming January 18, 2015 07:22AM |
KimBrown
I have a theory about the hotend, that when we feed the filament in afresh, that with sharp corners on the edge of the filament, the filament picks up a small bit of the PTFE tubing as it goes from the Bowden tube in to the short length of tubing in the Hotend.... Some times these particles lodge inside the Hotend, and when there is enough, it either blocks the nozzle partially or totally. I noticed a couple of times that the short length of PTFE tubing inside the Hotend had disintegrated. Now when I feed in fresh filament I chamfer the leading edge of the filament, and it stops it.
ormerod168
Erik (LOL)
Re: Extruder gears jamming January 18, 2015 11:48AM |
Sardi
Re: Extruder gears jamming January 18, 2015 12:07PM |
