New PanelDue firmware 1.01 January 27, 2015 04:06AM |
Temperatures, speeds and extrusion factors can now be adjusted in steps of 1 and 10
Temperatures being adjusted start off at zero if they are initially negative
Improved touch accuracy near screen edges
File list is now sorted and scrollable
Added factory reset button on Setup page
Fixed problem with print status bar appearing when no print is in progress and extrusion factor is adjusted
Only display 1 homing button if the printer is a delta
Re: New PanelDue firmware 1.01 January 27, 2015 05:28AM |
Re: New PanelDue firmware 1.01 January 27, 2015 05:39AM |
Re: New PanelDue firmware 1.01 January 27, 2015 06:36AM |
Re: New PanelDue firmware 1.01 January 27, 2015 07:05AM |
Re: New PanelDue firmware 1.01 January 27, 2015 09:23AM |
Re: New PanelDue firmware 1.01 January 27, 2015 09:33AM |
dc42
Doug, I need to add some more support in the Duet firmware before the PanelDue knows it is a delta. This should be in version 1.00c.
X4FF3, thanks for making a 5 inch binary available.
Feature idea / request January 29, 2015 05:29PM |
Re: Feature idea / request January 29, 2015 06:15PM |
Re: Feature idea / request January 31, 2015 09:35AM |
* Baud rate can now be configured. The default baud rate has been reduced to 57600.
* Checksums are included in all commands sent to the Duet.
* Added option to invert the display.
* Added some quick commands on the Control page (G92 Z0, G1 X0 Y0, G1 Z1, G32).
Re: Feature idea / request January 31, 2015 10:37AM |
dc42
I've just released PanelDue firmware 1.02. Changes in this release:
This version works best with Duet firmware 1.00d. If you use it with an earlier version of Duet firmware, you will need to increase the baud rate of the PanelDue to 115200.
Re: New PanelDue firmware 1.01 February 02, 2015 03:04PM |
Re: New PanelDue firmware 1.01 February 02, 2015 03:33PM |
Re: New PanelDue firmware 1.01 February 02, 2015 05:14PM |
Re: New PanelDue firmware 1.01 February 02, 2015 05:44PM |
Re: New PanelDue firmware 1.01 February 02, 2015 08:11PM |
Re: New PanelDue firmware 1.01 February 03, 2015 03:04PM |
Re: New PanelDue firmware 1.01 February 03, 2015 03:29PM |
Re: New PanelDue firmware 1.01 February 03, 2015 04:41PM |
Re: New PanelDue firmware 1.01 February 03, 2015 06:07PM |
Re: New PanelDue firmware 1.01 February 04, 2015 08:40PM |
Re: New PanelDue firmware 1.01 February 07, 2015 03:09PM |
Corrected typo in quick commands
SD card files can now be deleted
Added "Are you sure?" dialog
Beep volume can be adjusted
Separate button to save settings
Show baud rate on Settings screen
Re: New PanelDue firmware 1.01 February 16, 2015 07:37AM |
Re: New PanelDue firmware 1.01 February 16, 2015 08:43AM |
wayno complaino
Can the SD card slot on the LCD screen be used in place of the micro SD on the Duet board? I ask as trying to have a tidy install and the duet cased means the micro sd is hard to get to. With the LCD's SD slot being nice and easy it makes sense to utilise it. Thanks in advance!
Re: New PanelDue firmware 1.01 February 16, 2015 08:58AM |
wayno complaino
Re: New PanelDue firmware 1.01 February 16, 2015 11:03AM |
Re: New PanelDue firmware 1.01 February 17, 2015 09:59AM |
dc42
I've just released PanelDue firmware 1.03. Changes in this release:
A binary for 4.3 inch screens can be found via [github.com].
Re: New PanelDue firmware 1.01 February 17, 2015 11:23AM |
Re: New PanelDue firmware 1.01 February 17, 2015 11:55AM |
Re: New PanelDue firmware 1.01 February 17, 2015 04:57PM |
