Do you lubricate your Z axis ? March 10, 2015 11:11AM |
Re: Do you lubricate your Z axis ? March 10, 2015 11:28AM |
Don Recardo
Do you lubricate your Z axis ? no, that's not a euphemism , do you oil the 5mm threaded rod that lifts the X arm up and down?
I did but found it caused problems , where the oil had been it started to create a black buildup , ( it felt a bit rubbery ) . I dont know if its the oil mixing with
dust in the air , or maybe fine filings as the nut wears out but what ever it was it made it hard to turn the Z axis and worse still it was abrasive and wore the thread off the trapped Z nut
to the extent that I have had the X-arm crash down to the bed because the thread in the nut had worn so much it couldn't grip the threaded rod .
I have so far put about 1.5Kg of filament through the machine and already I am my third trapped nut . The other two just wore their thread away , although the thread on the 5mm rod is fine,
I guess its stainless steel and harder than the nut.
Since then I stopped oiling the rod and so far its been fine , but I wondered if anyone else had the same issue or if not , what do you lubricate it with ?
Don
Re: Do you lubricate your Z axis ? March 10, 2015 12:59PM |
Re: Do you lubricate your Z axis ? March 10, 2015 03:17PM |
Re: Do you lubricate your Z axis ? March 10, 2015 05:46PM |
Re: Do you lubricate your Z axis ? March 11, 2015 07:03AM |
Re: Do you lubricate your Z axis ? March 11, 2015 12:21PM |
Re: Do you lubricate your Z axis ? March 11, 2015 02:22PM |
fotomas
Don Recardo
I printed and fitted the Y axis bearing holder with adjuster for setting the bed level
Interesting, what is this part? Link?
/Tomas
Re: Do you lubricate your Z axis ? March 11, 2015 03:21PM |
Re: Do you lubricate your Z axis ? March 11, 2015 08:26PM |
fotomas
Ha ha, that's funny. That part is my creation. And the reason for me asking for a link was to se what else there is out there to improve bed levelling. And then you link to "my" part, just lovely!
